We are working on migrating our existing applications from SDO_Geometry into ST_Geometry (Oracle 11g - SDE 10.2.2).
One of our applications uses an iPad to get the X, Y coordinates and locate the closest linear asset.
Our SDO sql statement was simple:
WHERE SDO_WITHIN_DISTANCE ( A.AREAGEOMETRY ,mdsys.sdo_geometry(2001, 8307,
mdsys.sdo_point_type( -78.2990416, 44.29297897, NULL), NULL, NULL), 'distance=75') = 'TRUE'
The response time is 196 msecs
Attempting to duplicate the results using ST functions is a little frustrating
I have not been able to us the x, y points from the iPad at all, so I've been uisng the UTM coordinates.
I've been able to reproduce the results using the UTM coordinates but the response time is way too slow (see below)
14 secs
where sde.st_intersects (sde.st_buffer(sde.st_point(715480.6, 4907962.3, 26917), 15 ),pl.shape) = 1
11 secs
where sde.st_distance (sde.st_point(715480.6, 4907962.3, 26917),pl.shape) < 15
9 secs
where sde.st_distance (sde.st_geometry(715480.6, 4907962.3,null,null, 26917),pl.shape) < 15
Does anyone have any advice for how to speed the response time up?
Are these the correct sql functions? or am I missing one?
Please let me know.
Not having the data, and not having the time to simulate some, I'm not fond of specifying a query, but something like:
WHERE sde.st_envintersects(pl.shape,715480.6-15,4907962.3-15,715480.6+15,4907962.3+15) = 1
and sde.st_distance (sde.st_geometry(715480.6, 4907962.3,null,null, 26917),pl.shape) < 15
ought to work reasonably quickly.
You need to review the query plan to determine whether the index is being used, but I can't give you further information than that. You may need to work with Tech Support to determine the optimal query (it doesn't help that the old query was in WGS_1984). It's possible that a 530 meter index grid is inappropriate for that dataset (but couldn't say for sure without the data).
BTW: change the "15"s to "75"s if you want a similar result as Oracle with a "75" query.
- V
