I'd like to use a ArcGISDynamicMapServiceLayer and a WMTS_layer from Swisstopo (http://wmts.geo.admin.ch). When I'm loading the ArcGISDynamicMapServiceLayer first the WMTS Layer will not be loaded. I think there is something about the different LOD's. How can this be solved?
var map;
require(["esri/map", "esri/layers/WMTSLayer", "dojo/domReady!"], function(Map, WMTSLayer) {
var extent = new esri.geometry.Extent(595171.7678435356, 200875.0317500635, 702328.2321564644, 294124.9682499365, new esri.SpatialReference({
"wkid": 21781
map = new Map("map", {
//basemap: "topo",
//center: [7.537513, 47.208331], // longitude, latitude
// zoom: 13
extent: extent
esri.config.defaults.io.proxyUrl = "../proxy/PHP/proxy.php";
// esriConfig.defaults.io.alwaysUseProxy = false;
var layerinfo = new esri.layers.WMTSLayerInfo({
identifier: 'ch.swisstopo.pixelkarte-grau'
var options = {
layerInfo: layerinfo
var wmts = new WMTSLayer("http://wmts.geo.admin.ch", options);
var luftbild = new esri.layers.ArcGISTiledMapServiceLayer("https://quality.ag.ch/geoportal/rest/services/base_ortho2013_full/MapServer", {
var giselan = new esri.layers.ArcGISDynamicMapServiceLayer("https://www.ag.ch/geoportal/rest/services/lwag_giselan_app/MapServer", {
map.on("load", function(map){
var i = 10;
map.addLayer(luftbild);
map.addLayer(wmts);
// map.addLayer(giselan);
