Portal Geocode with in-house geocode utility service inferior to Toolbox Geocode
3882
02-10-2015 11:36 AM
JustinKoppa
I have a geocode service that performs much better in Desktop than Portal tested by geocoding the same spreadsheet.  Geocoding with Toolbox provides a 84% success rate while geocoding conducted in Portal utilizing same geocode utility service produced only a 20% success rate.   What could explain this large discrepancy?  Anyone else experienced this?
AgathaWong
New Contributor III
Justin, would you mind share your locator and test addresses so that I can take a look? You can email or share the data in drop box with me.
Agatha Wong
Esri
awong@esri.com
AgathaWong
New Contributor III
Agatha Wong
Esri
awong@esri.com
JustinKoppa
Agatha suggested I re-create the geo-locator using dual ranges and that seemed to do the trick.  Portal is now geocoding the same dataset similar to what Desktop does.
Thank you Agatha!
