Set Function with addtional field printed
3790
02-09-2015 08:49 AM
LarryAdgate
Some help on this please, Thanks
Script work works great for finding Facilityid numbers not found in “b” or final =a-b. But to make the script more useful an additional field or
“NAME” should be printed in conjunction with the Facilityid number or “FACILITYID & NAME” and this is where I need some help. The “NAME” field contains text (ex:“Redondo Tank”) and is difficult to add or subtract and the set function works perfect for my task.
Larry Adgate
# Import arcpy module
import arcpy
# Local variables:
Index = "C:\\Projects\\UpdatePlantFacilityIndex.mdb\\FacilityIndex2013"
Arden_ns = "C:\\Projects\\UpdatePlantFacilityIndex.mdb\\UpdatePlantFacilityIndex\\Network"
a = set(r[0] for r in arcpy.da.SearchCursor(Index, ["FACILITYID"]))
a1 = set(r[0] for r in arcpy.da.SearchCursor(Index, ["NAME"])) #Addition field data to accompany FacilityID
b = set(r[0] for r in arcpy.da.SearchCursor(Arden_ns, ["FacilityID"]))
final = a+a1-b
print "Arden System Discrepency: {0},".format(", ".join(sorted(final)))
#error Message:    final = a+a1-b
#error message: TypeError: unsupported operand type(s) for +: 'set' and 'set'
Tags (1)
XanderBakker
Esri Esteemed Contributor
You could try this:
import arcpy
# list of facility ID's in Arden_ns
# list facilities not in arden_ns
flds= ("FACILITYID", "NAME")
dct = {r[0]: r[1] for r in arcpy.da.SearchCursor(Index, flds) if not r[0] in b}
# print list
for fac_id, name in sorted(dct.items()):
    print "{0}: {1}".format(fac_id, name)
XanderBakker
Do the FacilityID and NAME fields contain the same information? In my post Some Python Snippets you can see how to work with sets and lists:
# Compare two lists and get the items in list 1 but not in list 2
listDifference = list(set(myList1) - set(myList2))
# Compare two lists and get the items that are in both lists
listSame = list(set(myList1) & set(myList2))
# join or merge two sets
new_set = first_set.union(other_set)
# or:
new_set = set(list(first_set) + list(other_set))
LarryAdgate
Xander Thanks for your Help
The " FacilityId" Field will contains numbers such as NS1025, NS1008, NS1010, CS1002
The "NAME" Field will contain text data such as- Redondo Tank, Sludge Tank, Pacific Tank
A Typical Print out would say:   NS1025  Redondo Tank
                                                  NS1008  Sludge Tank
                                                  NS1010  Pacific Tank
Larry
XanderBakker
You could try this:
import arcpy
# print list
LarryAdgate
Thanks Xander,  the script worked great. My plans were to run  the Index againt 38 other feature classes and this will give me food for thought. Thanks, Larry
