UniqueValueRenderer
4017
02-06-2015 06:12 AM
BrianPaulson1
I was able to duplicate this example:Feature collection | ArcGIS API for JavaScript
using point data in a SQL Server Table (Web service which returns Json format data from SQL Server).
I am wondering how I would make it so that the last point entered is a different color than the rest of the points?  I am guessing I would have to use UniqueValueRenderer and assign the Maximum ObjectID Value a different color? That was the route I was going, but couldn't get it to work. Any help would be greatly appreciated.  Thanks
RobertScheitlin__GISP
Brain,
  Here is a sample that handles this without a uniquevaluerenderer.
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the
    samples on iOS devices-->
    <title>Flickr</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.12/esri/css/esri.css">
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
      .esriScalebar{
        padding: 20px 20px;
      #map{
        padding:0;
    </style>
    <script>var dojoConfig = { parseOnLoad: true };</script>
    <script src="http://js.arcgis.com/3.12/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "esri/layers/FeatureLayer",
        "esri/dijit/PopupTemplate",
        "esri/request",
        "esri/geometry/Point",
        "esri/graphic",
        "esri/symbols/PictureMarkerSymbol",
        "dojo/on",
        "dojo/_base/array",
        "dojo/domReady!"
      ], function(
        Map,
        FeatureLayer,
        PopupTemplate,
        esriRequest,
        Point,
        Graphic,
        PictureMarkerSymbol,
        on,
        array
        var featureLayer;
        map = new Map("map", {
          basemap: "satellite",
          center: [-46.807, 32.553],
          zoom: 3
        //hide the popup if its outside the map's extent
        map.on("mouse-drag", function(evt) {
          if (map.infoWindow.isShowing) {
            var loc = map.infoWindow.getSelectedFeature().geometry;
            if (!map.extent.contains(loc)) {
              map.infoWindow.hide();
        //create a feature collection for the flickr photos
        var featureCollection = {
          "layerDefinition": null,
          "featureSet": {
            "features": [],
            "geometryType": "esriGeometryPoint"
        featureCollection.layerDefinition = {
          "geometryType": "esriGeometryPoint",
          "objectIdField": "ObjectID",
          "drawingInfo": {
            "renderer": {
              "type": "simple",
              "symbol": {
                "type": "esriPMS",
                "url": "images/flickr.png",
                "contentType": "image/png",
                "width": 15,
                "height": 15
          "fields": [{
            "name": "ObjectID",
            "alias": "ObjectID",
            "type": "esriFieldTypeOID"
            "name": "description",
            "alias": "Description",
            "type": "esriFieldTypeString"
            "name": "title",
            "alias": "Title",
        //define a popup template
        var popupTemplate = new PopupTemplate({
          title: "{title}",
          description: "{description}"
        //create a feature layer based on the feature collection
        featureLayer = new FeatureLayer(featureCollection, {
          infoTemplate: popupTemplate
        //associate the features with the popup on click
        featureLayer.on("click", function(evt) {
          map.infoWindow.setFeatures([evt.graphic]);
        map.on("layers-add-result", function(results) {
          requestPhotos();
        //add the feature layer that contains the flickr photos to the map
        map.addLayers([featureLayer]);
      function requestPhotos() {
        //get geotagged photos from flickr
        //tags=flower&tagmode=all
        var requestHandle = esriRequest({
          url: "http://api.flickr.com/services/feeds/geo?&format=json",
          callbackParamName: "jsoncallback"
        requestHandle.then(requestSucceeded, requestFailed);
      function requestSucceeded(response, io) {
        //loop through the items and add to the feature layer
        var features = [];
        array.forEach(response.items, function(item, index) {
          var attr = {};
          attr["description"] = item.description;
          attr["title"] = item.title ? item.title : "Flickr Photo";
          var geometry = new Point(item);
          var graphic = new Graphic(geometry);
          if(index == response.items.length - 1){
            var symbol = new PictureMarkerSymbol({
                "type": "esriPMS",
                "width": 30,
                "height": 30
            graphic.setSymbol(symbol);
          graphic.setAttributes(attr);
          features.push(graphic);
        featureLayer.applyEdits(features, null, null);
      function requestFailed(error) {
        console.log('failed');
    </script>
  </head>
  <body >
    <div id="map"></div>
  </body>
</html>
Brain,
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
      .esriScalebar{
        padding: 20px 20px;
      #map{
        padding:0;
    </style>
    <script>
      var map;
      require([
        "esri/map",
        "esri/request",
        "esri/graphic",
        "dojo/on",
        "dojo/_base/array",
        "dojo/domReady!"
      ], function(
        Map,
        FeatureLayer,
        PopupTemplate,
        esriRequest,
        Point,
        Graphic,
        on,
        array
        var featureLayer;
          zoom: 3
          "featureSet": {
            "features": [],
          "drawingInfo": {
            "renderer": {
              "type": "simple",
              "symbol": {
                "type": "esriPMS",
                "width": 15,
                "height": 15
          "fields": [{
            "name": "ObjectID",
            "name": "title",
            "alias": "Title",
          title: "{title}",
          requestPhotos();
        var features = [];
          var attr = {};
                "type": "esriPMS",
                "width": 30,
                "height": 30
    </script>
  </head>
  <body >
  </body>
</html>
