3D TIN in ArcGIS Pro
4862
02-05-2015 11:38 PM
KennethDudley
I've been trying to display a TIN as a 3D layer in ArcGIS Pro and have not been able to do so. I can get it to show up in 2D layers but I'm unable to drag it to 3D. I can open the multipoint .shp file I have and see that in 3D (from which I created the TIN). I made the TIN in 10.2. I can make the TIN the "elevation surface" which seems to work fine, though I'd like to see the TIN.
Has anyone gotten this to work?
JeremyWright
In Pro 1.0 you can use the TIN as an elevation surface or a member of an elevation surface, and you can use the symbolized TIN in the 2D layers group (which means it will be rasterized).  Viewing the TIN "as a tin" meaning separately as a vector 3D layer is something we hope to add in a future release.
JeremyWright
AlessandroValra
Occasional Contributor III
ArcGIS Pro 1.4 (2017) same situation...
