Count How many vertices
4942
5
02-05-2015 12:31 PM
PROBERT68
Is there a way for me to run a tool or script to call how many vertices of a file geodatabase polygon ?
MicahBabinski
Occasional Contributor III
Yes, Tim is right on with that GP tool. Try:
# Import arcpy
import arcpy
# Define the tool parameters
in_fc = r"[path_to_your_polygon_fc]"
out_fc = r"[path_to_point_fc]"
# Convert the feature vertices to points
arcpy.FeatureVerticesToPoints_management(in_fc, out_fc)
# Count the features and print the answer
print(int(arcpy.GetCount_management(out_fc).getOutput(0)))
I hope it works for you!
Warm Regards,
Micah Babinski
TimWitt2
Robert,
maybe this can help? ArcGIS Help 10.1
Tim
OwenEarley
You could use the Feature Vertices To Points (Data Management) tool - ArcGIS Help 10.1
Make sure to use the ALL option:
Summary
Creates a feature class containing points generated from specified vertices or locations of the input features.
Illustration
MicahBabinski
# Import arcpy
import arcpy
Warm Regards,
Micah Babinski
PROBERT68
Is that for shapefiles only ? What about geodatabases ?
PROBERT68
Never mind. I got it to work.
