applyEdits JavaScript API
5592
02-05-2015 02:20 AM
BadarGillani
applyEdits on a polyline FeatureLayer is throwing the error message "Invalid or missing input parameters". The relevant code is given below for reference:
function requestCreateFeature() {
   //loop through the items and add to the feature layer
   var feature = [];
   var attr = {};
   var d = new Date();
var geometry;
   if (featType =="point") {
    var myx = pxmin.value;  // value from a user input texbox
    var myy = pymin.value; // value from a user input textbox
    geometry = new Point(myx,myy,map.spatialReference);
   } else {
    var myxmin = lxmin.value;  // values from a user inputtexbox
    var myymin = lymin.value;  // value from a user inputtexbox
    var myxmax = lxmax.value;  // value from a user input texbox
    var myymax = lymax.value;  // value from a user input texbox
    geometry = new Polyline ([[myxmin, myymin],[myxmax, myymax]]);
   attr["sapname"] = pname;      // value from a user input texbox
   attr["creation_date"] = d.toUTCString();
   attr["status"] = 1;
   var graphic = new Graphic(geometry);
   graphic.setAttributes(attr);
   feature.push(graphic);
   myFeature.applyEdits(feature, null, null, onsucess, onerror);
function onsucess(evt) {
   alert("Edit successful...");
  function onerror(evt){
   alert("There is some error in creation...");
MichaelKelly
Occasional Contributor III
Instead of creating the feature array like this
     var feature = [];
apply that in the applyEdits function.
The following works for me (feature service has to be changed):
var myFeature= new FeatureLayer("http://services.arcgis.com/feww435rERdff45/ArcGIS/rest/services/featureName/FeatureServer/0", {
    mode: FeatureLayer.SELECTION_NEW
var feature = {};
feature["attributes"] = {};
feature["attributes"].DATE = new Date().toString();
feature["geometry"] = geometry;
myFeature.applyEdits([feature], null, null, onsucess, onerror);
