Run a function which inside the main function
3916
02-05-2015 12:00 AM
AysberqTundra
Hi.
My question is about ArcGIS JS Api.
For some reasons I need to run a function which inside the main function from outside of main function.
How can I do it? Is there any way to do it?
<script>
    require([
      "esri/map",
      "dojo/domReady!"
    ], function(
      Map,...
      var map = new Map("map", {
        center: [-56.049, 38.485],
        zoom: 3,
        basemap: "streets"
     function MyInnerFunction(){
        //body of inner funcion
  });  //End of the main function
MyInnerFunction();   //Run inner function
</script>
OwenEarley
Occasional Contributor III
Not sure if anyone has a better approach but as long as dojo has finished loading you can use dojo.setObject() to expose the inner function.
    <script>
      var map;
      require([
        "esri/map",
        "dojo/domReady!"
      function(Map) {
        function myInnerFunction(){
          alert("Hi from MyInnerFunction");
        dojo.setObject('myInnerFunction', myInnerFunction);
          basemap: "topo",
          center: [-122.45, 37.75], // longitude, latitude
          zoom: 13
    </script>
See this Simple Map with a button at the top left that calls a function within the require function.
OwenEarley
    <script>
      var map;
      require([
        "esri/map",
        "dojo/domReady!"
      function(Map) {
          basemap: "topo",
          zoom: 13
    </script>
AysberqTundra
Thanks, Owen.
It worked perfectly for me.
