hi All
I am trying to export the DWG file from arc catalogue 10.2.2 to Shp. It is giving me the Error 000000_12301899.
I have tried to delete the normal.gxt from the user profile and also repaired the Software.
it is working good in arcmap but not with arc Catalogue.
Please help.
Strange, one would expect the same behavior in ArcMap as in ArcCatalog... I can't find much about that error (although it is also listed when converting a raster to a TIN).
What if you use the Catalog window inside ArcMap, does it reproduce the error? I hardly ever use ArcCatalog as application from the moment the Catalog window inside ArcMap was released.
It the error maintains, you may want to log it as a bug at Esri support.
