CityEngine Webscene Export Issue
4183
01-28-2015 12:14 AM
BrunoSeiler
Hi! I am working on a scene with building footprints. The shape names were adjusted during the working process. Example: a building footprint had the name A10 at the beginning and was renamed to A01 later on (just by typing in the name in the inspector). I exported both versions to Webscenes. The export worked fine, but when I click on the renamed shapes in the Webscene, they still have the old names and I can not find the new names in the webscene when I search for them. I already tried the following:
-export with CityEngine default settings instead of previous export settings
-copying the shapes to a new layer and exporting
-exporting the shapes without applying a rule file
All with the same result. Has anyone got an idea how this issue can be solved? Re-importing the shapes would be very time consuming as I would then have to set many cga-attributes for every footprint to rebuild the scene.
MatthiasBuehler
Occasional Contributor III
Hey Bruno!
Next to the shape name, can you create an object attribute and check if that value 'survives' the way to the WebScene and is visible in the green info dialog?
Matt
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
Garsdale Design Limited
matthias.buehler@garsdaledesign.co.uk
www.garsdaledesign.co.uk
BrunoSeiler
Hi Matt!
Thanks for your answer! The object attribute survives the export.
It's very odd... If I change the shape name to something completely different, like 'abc' the export also works. But if I use the names as described above it doesn't work. Seems that CityEngine gets confused when I use the same names as before, but apply them to different shapes (if shape 1 gets name of shape 2 and vice versa).
I just found a simple workaround: If I add a space at the end of the name it works.
MatthiasBuehler
Hi ..
I assume somewhere in the process, the file endings are checked for numbers to sort things. Then if there's numbers, they may be adapted.
This would be a bug, I assume.
But maybe just put and underscore at the end and try again and see if you get new numbers at the very end..
Matt
Matthias Buehler
twitter: @MattB3D
