How to minimize and maximize widget ?
7188
6
01-27-2015 04:09 AM
AmeyaNatu1
New Contributor III
I am developing a widget where as per client resolution I want to change widget state like minimize and maximize. However I have followed following documentation but still no help.
Close widget programmatically—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
I have followed the WidgetManager class but not able to work with that class.
RobertScheitlin__GISP
Ameya,
   Can ou post the code that you have tried? Are you using the Tab theme or the foldable theme?
AmeyaNatu1
New Contributor III
Initially I have tried to to use WidgetManager class, because in that class there are two methods one is maximizeWidget and another is minimizeWidget. However I have access them on my function but nothing widget is not minimizing or maximizing. Therefore I have looked for the code for minimizing and maximizing button the widget panel and I have found following code which is giving me auto minimize and maximize functionality in my widget .
this.panelManager.getPanelById(this.id + '_panel').onTitleClick();
Sai_PhaneendraPoludasu2
New Contributor III
I have the same question.
I have tried Widget Manager's minimizeWidget and maximizeWidget methods and see no use of those methods. Using
is an alternate to achieve this for foldable theme, but the same does not work for tabbed theme. Any help in understanding how to do this is appreciated.
Thanks in advance.
LarryStout
Occasional Contributor III
Try this:
this.panelManager.closePanel(this.id + '_panel'); // To close the panel
this.panelManager.showPanel(this.id + '_panel'); // To show the panel
this.panelManager.minimizePanel(this.id + '_panel'); // To minimize the panel
this.panelManager.maximizePanel(this.id + '_panel'); // To maximize the panel
Larry
New Contributor III
Thanks for your inputs on this Larry.
As said by Ameya in his description earlier I have tried using minimizePanel and maximizePanel as suggested  in Close widget programmatically—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers​.
But that didn't help, also the alternate titleClick works only for foldable theme and not for other themes and floating place holders.
JunshanLiu
It's an issue that panelManager.minimizePanel() doesn't work, we'll fix it in next release.
About how to minimize/maximize widget/panel programmatically?
You can have a look at the minimizeWidget() function in widgetManager, it's very simple. It just change the widget's window state and call widget's onMinimize() function. So, it's widget's job to minimize itself in it's onMinimize() function. Panel has the similar design pattern.
For off-panel widget, you should use widgetManager.minimizeWidget(widgetId);
For in-panel widget, you should use panelManager.minimizePanel(panelId);
  panelId=widgetId + '_panel', you can also use widget.getPanel() to get widget's panel in next release.
