Merge layer files
4570
01-25-2015 11:21 PM
Yaron_YosefCohen
Occasional Contributor II
Hello everyone,
I try to merge layer files that spread in big folder that divided to a lot of sub folders. all the layer files as different names.
continuously to Xander  answer in https://community.esri.com/thread/120535  , how do i chagne this code so i will can merge all the layer files ? i tried this code but it doesn't work out:
import arcpy,os,sys,string,fnmatch
import arcpy.mapping
from arcpy import env
rootPath = r"C:\Project\layers"
pattern = '*.lyr'
lyr2merge = []
counter = 0
for root, dirs, files in os.walk(rootPath):
    for filename in fnmatch.filter(files, pattern):
        lyr2merge.append(os.path.join(root, filename))
        counter = counter + 1
arcpy.Merge_management(lyr2merge, r"C:\Project\layers\layer_total.lyr")
print 'merge'
print counter
KishorGhatage
Occasional Contributor III
In the merge output use .shp instead of .lyr.
Yaron_YosefCohen
bbut then i have to convert shp to lyr file.
i want to skip this phase
PeterVersteeg
Looking at the merge tool i think the output will by .shp even with lyr input. perhaps what you could do is make a script that selects all features from one layer and copy past it to the other feature. In arcmap this works
gr peter
