IFeatureSelection,SelectFeatures throwing error.
6805
7
01-26-2015 05:39 AM
SanajyJadhav
Occasional Contributor II
We have a simple code for selecting features based on attribute query using IFeatureSelection. However, it throws COMexception at the line where it selects the features. Error is Exception from HRESULT: 0x80041538.
Initially I suspected that problem would be with the syntax of the where clause, but even simpler where clauses like "OBJECTID = 500'" also throw error. I have confirmed that the features being queried actually exist in the feature class.Error screenshot is attached here.
Code:
Public Sub LayerSelectFeatures(ByRef pFlayer As IFeatureLayer, ByVal strFWhereClause As String, ByVal enumSelectionResult As esriSelectionResultEnum)           Try                         Dim pMxDoc As IMxDocument             pMxDoc = g_pApp.Document             Dim pMap As IMap             pMap = pMxDoc.FocusMap             Dim pActiveView As IActiveView             pActiveView = pMap               Dim pQueryFilter As IQueryFilter             pQueryFilter = New QueryFilterClass             pQueryFilter.WhereClause = strFWhereClause                          Dim pLayerSelection As IFeatureSelection             pLayerSelection = TryCast(pFlayer, ESRI.ArcGIS.Carto.IFeatureSelection)                              pActiveView.PartialRefresh(esriViewDrawPhase.esriViewGeoSelection, Nothing, Nothing)             pLayerSelection.SelectFeatures(pQueryFilter, esriSelectionResultEnum.esriSelectionResultAdd, False) 'Erractic Line             pActiveView.PartialRefresh(esriViewDrawPhase.esriViewGeoSelection, Nothing, Nothing)               System.Runtime.InteropServices.Marshal.ReleaseComObject(pQueryFilter)             pQueryFilter = Nothing           Catch ex As Exception           End Try       End Sub
ArcMap Version : 10.2.1
Database: SDE on Oracle 11 g
Language : VB.Net
I would appreciate if I can get help to fix this issue.
PS: When I use esriSelectionResultNew instead of esriSelectionResultAdd, it works.
Thanks.
SanajyJadhav
Owen,
The line below did the trick.
GRANT UNLIMITED TABLESPACE TO <USERNAME>;
I guess you had guided me in that direction and I had tried it. but it did not work then. I had tried that through the UI of the Toad.
But I ran the above mentioned line in the Editor of the Toad and it did the trick.
Appreciate your help.
JeffMorton
I was getting that same error. I looked at the query filter string that I was sending and discovered a SQL error in it.
SanajyJadhav
Thanks for the response Jeff.
In my case, my where clause is correct, I have confirmed it.
SanajyJadhav
I investigated this issue further and found that this error occurs while editing SDE feature class and not MDB or FGDB. To narrow down this,I enabled sde intercepts on my machine ( client ) and reproduced the error. The intercept produced large data to go through. Still, I found one oracle error that has been repeating itself.
This error was "ORA-01950: no privileges on tablespace 'USERS'. Below is some extract from the intercept.
[R 16:53:29.476] Command:      GetConnectionError
[W 16:53:29.476] Long:         -51
[W 16:53:29.476] Long:         1950
[W 16:53:29.476] NString:      "ORA-01950: no privileges on tablespace 'USERS'
ORA-06512: at line 1
So,I was wondering if anybody had got this error. Any help is appreicated.
S.
OwenEarley
Occasional Contributor III
From memory SDE stores feature classes selection sets within the database. You may want to look at this StackOverflow post about quotas. This is probably a long-shot but it is worth ruling out as a potential cause.
SanajyJadhav
Owen,
Thanks for your reply.
I gave unlimited  quota the table space to my user but it did not work.
This issue has something to do woth the grants and privillges I tihnk because when I give dba role to the user, the error does not occur.
Any other suggestions?
Thanks once again.
S.
OwenEarley
Definitely sounds like a permissions issue but you don't want to be handing out the dba role to all your users .
It has been a while since I have been involved in doing any SDE administration. Hopefully, someone with some more recent experience sees this and can make a suggestion.
I did find this old help file that explains what is created during the selection process - not sure if any of this has changed in version 10.
There is also this new help file that may provide some pointers. It also points to a potential issue with the user not having permissions for the Oracle tables used to store selection sets:
Tables created for shared log files
The log file tables used for this option are SDE_LOGFILES and SDE_LOGFILE_DATA. They are created in the schema of the connecting user the first time the user makes a selection that exceeds the selection threshold. For ArcGIS for Desktop, this threshold is 100 records.
SDE_LOGFILES stores information about each selection set (log file) that is created. The logfile_name and logfile_id columns in this table uniquely identify the name of the log file, and the logfile_id column links the log file record to the SDE_LOGFILE_DATA table. The SDE_LOGFILE_DATA table contains the logfile_data_id and the feature identifier for the selected records.
All records are deleted as soon as the selection set is cleared to prevent the SDE_LOGFILE_DATA table from growing too large. The SDE_LOGFILES table is truncated when the user's session ends. Both SDE_LOGFILE_DATA and SDE_LOGFILES remain in the user's schema.
SanajyJadhav
Owen,
