AnsweredAssumed Answered
How to get Journal Map to run on non-AGOL server?
Question asked by dwardio on Jan 20, 2015
Latest reply on Jan 20, 2015 by dwardio
Working from a Journal Map that was created in AGOL, I'm attempting to create a more customized version using code esri has made available on github (  Esri/map-journal-storytelling-template-js · GitHub  ).
Although the AGOL version works fine ( https://neon.maps.arcgis.com/apps/MapJournal/?appid=e1fbef1ed7e147cd9f76c24587c19740 ), adding the same appid to line 38 of the index.html file results in a "Web Mapping Application identifier not specified in index.html" error.
I'm running MAMP on my laptop as a local webserver -- my normal development environment. View Source shows " appid: "e1fbef1ed7e147cd9f76c24587c19740", " on line 38.
Any suggestions?  I am well and truly stumped at this point!
Ultimately, my goal is to add a reference map in the upper left corner similar to this: The Age of Megacities . I get that I'll need to edit some JS and CSS, but I'm stuck until I get the original up and running on my dev server.
Can someone point me in the right direction?
Outcomes
