I followed tutorial(Hello world) but it doesn't work
I made some app using eclipse&arcgis sdk before, it work well in that time...
But Android Studio is unfamilliar
I searched for the same problem and advices are just for eclipse..
here are codes, I just wonder why android studio can't read class com.esri.android.map.MapView
Logcat-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
01-20 04:55:28.590 2151-2151/com.esri.android.tutorials.helloworld E/art﹕ dlopen("/data/app/com.esri.android.tutorials.helloworld-1/lib/x86/libruntimecore_java.so", RTLD_LAZY) failed: dlopen failed: "/data/app/com.esri.android.tutorials.helloworld-1/lib/x86/libruntimecore_java.so" has unexpected e_machine: 40
01-20 04:55:28.590 2151-2151/com.esri.android.tutorials.helloworld D/AndroidRuntime﹕ Shutting down VM
01-20 04:55:28.590 2151-2151/com.esri.android.tutorials.helloworld E/AndroidRuntime﹕ FATAL EXCEPTION: main
Process: com.esri.android.tutorials.helloworld, PID: 2151
java.lang.RuntimeException: Unable to start activity ComponentInfo{com.esri.android.tutorials.helloworld/com.esri.android.tutorials.helloworld.MainActivity}: android.view.InflateException: Binary XML file line #8: Error inflating class com.esri.android.map.MapView
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2298)
at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2360)
at android.app.ActivityThread.access$800(ActivityThread.java:144)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1278)
at android.os.Handler.dispatchMessage(Handler.java:102)
at android.os.Looper.loop(Looper.java:135)
at android.app.ActivityThread.main(ActivityThread.java:5221)
at java.lang.reflect.Method.invoke(Native Method)
at java.lang.reflect.Method.invoke(Method.java:372)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:899)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:694)
Caused by: android.view.InflateException: Binary XML file line #8: Error inflating class com.esri.android.map.MapView
at android.view.LayoutInflater.createView(LayoutInflater.java:633)
at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:743)
at android.view.LayoutInflater.rInflate(LayoutInflater.java:806)
at android.view.LayoutInflater.inflate(LayoutInflater.java:504)
at android.view.LayoutInflater.inflate(LayoutInflater.java:414)
at android.view.LayoutInflater.inflate(LayoutInflater.java:365)
at android.support.v7.app.ActionBarActivityDelegateBase.setContentView(ActionBarActivityDelegateBase.java:228)
at android.support.v7.app.ActionBarActivity.setContentView(ActionBarActivity.java:102)
at com.esri.android.tutorials.helloworld.MainActivity.onCreate(MainActivity.java:14)
at android.app.Activity.performCreate(Activity.java:5933)
at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1105)
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2251)
Caused by: java.lang.reflect.InvocationTargetException
at java.lang.reflect.Constructor.newInstance(Native Method)
at java.lang.reflect.Constructor.newInstance(Constructor.java:288)
at android.view.LayoutInflater.createView(LayoutInflater.java:607)
Caused by: java.lang.UnsatisfiedLinkError: dlopen failed: "/data/app/com.esri.android.tutorials.helloworld-1/lib/x86/libruntimecore_java.so" has unexpected e_machine: 40
at java.lang.Runtime.loadLibrary(Runtime.java:371)
at java.lang.System.loadLibrary(System.java:989)
at com.esri.core.internal.RuntimeHelper.a(SourceFile:85)
at com.esri.core.internal.RuntimeHelper.initialize(SourceFile:47)
at com.esri.android.map.MapSurface.<clinit>(SourceFile:68)
at com.esri.android.map.MapView.a(SourceFile:585)
at com.esri.android.map.MapView.<init>(SourceFile:620)
activity_main.xml--------------------------------------------------------------------------------------------------------------------------------------------------------
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:tools="http://schemas.android.com/tools" android:layout_width="match_parent"
android:layout_height="match_parent" android:paddingLeft="@dimen/activity_horizontal_margin"
android:paddingRight="@dimen/activity_horizontal_margin"
android:paddingTop="@dimen/activity_vertical_margin"
android:paddingBottom="@dimen/activity_vertical_margin" tools:context=".MainActivity">
<com.esri.android.map.MapView
android:id="@+id/map"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
mapoptions.MapType="Streets"
mapoptions.center="34.056215, -117.195668"
mapoptions.ZoomLevel="16">
</com.esri.android.map.MapView>
</RelativeLayout>
MainActivity.java-------------------------------------------------------------------------------------------------------------------------------------------------------
package com.esri.android.tutorials.helloworld;
import android.support.v7.app.ActionBarActivity;
import android.os.Bundle;
import android.view.Menu;
import android.view.MenuItem;
public class MainActivity extends ActionBarActivity {
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_main);
@Override
public boolean onCreateOptionsMenu(Menu menu) {
// Inflate the menu; this adds items to the action bar if it is present.
getMenuInflater().inflate(R.menu.menu_main, menu);
return true;
@Override
public boolean onOptionsItemSelected(MenuItem item) {
// Handle action bar item clicks here. The action bar will
// automatically handle clicks on the Home/Up button, so long
// as you specify a parent activity in AndroidManifest.xml.
int id = item.getItemId();
//noinspection SimplifiableIfStatement
if (id == R.id.action_settings) {
return true;
return super.onOptionsItemSelected(item);
build.gradle(Project HelloWorld)-------------------------------------------------------------------------------------------------------------------------------------------------------
// Top-level build file where you can add configuration options common to all sub-projects/modules.
buildscript {
repositories {
jcenter()
dependencies {
classpath 'com.android.tools.build:gradle:1.0.0'
// NOTE: Do not place your application dependencies here; they belong
// in the individual module build.gradle files
allprojects {
repositories {
jcenter()
maven {
url 'http://dl.bintray.com/esri/arcgis'
build.gradle(Module: app)-------------------------------------------------------------------------------------------------------------------------------------------------------
apply plugin: 'com.android.application'
android {
compileSdkVersion 21
buildToolsVersion "21.1.2"
packagingOptions{
exclude 'META-INF/LGPL2.1'
exclude 'META-INF/LICENSE'
exclude 'META-INF/NOTICE'
defaultConfig {
applicationId "com.esri.android.tutorials.helloworld"
minSdkVersion 15
targetSdkVersion 21
versionCode 1
versionName "1.0"
buildTypes {
release {
minifyEnabled false
proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.pro'
dependencies {
compile 'com.esri.arcgis.android:arcgis-android:10.2.5'
compile fileTree(dir: 'libs', include: ['*.jar'])
compile 'com.android.support:appcompat-v7:21.0.3'
How can I solve this Problem in Android Studio
Looks like you ran this sample with the emulator? Specifically the x86 emulator? We have a known issue with respect to using our AAR SDK bundle with x86 emulators. From our release notes:
> x86 native *.so files bundled in AAR do not work on android stock x86
> emulator. They do work on device. If you need to test on x86 emulator then you
> need to should not use the AAR bundle and instead add all the libs manually.
You can either create an ARM based emulator or use a physical device. If you must use an x86 emulator than you need to set up your app manually
