Configure Pop-Ups for Web Appbuilder
15940
01-13-2015 01:59 PM
KevinHatch
New Contributor III
I am having trouble configuring feature pop-ups in Web Appbuilder.
  1. If I enable a pop-up via the web map on a feature layer and the layer is toggled off by default the pop-up will NOT display in WAB when that layer is toggled on in the application.
  2. If the layer is toggled on in the web map initially the pop-up displays correctly in WAB.  Except that when you toggle the layer off in WAB the pop-up continues to appear anytime you click on the map even though the layer is no longer on.
My map contains a series of overlapping polygons that exist in separate layers.  They are toggled on and off as the user requires.  We require access to the pop-up window.  This is a big issue for us.  Hopefully it is just user error and an easy fix.
Tags (1)
TarigAhmed1
New Contributor III
I'm having the same issue. This is a big issue for us as well. take a look at this discussion
Identify Features
KevinHatch
New Contributor III
Thanks.  At least I know I am not crazy!
TarigAhmed1
New Contributor III
https://community.esri.com/message/449522?et=watches.email.thread#449522
ChrisAdams
BUG-000083263 - Layers that are checked off in WebApp Builder, but then checked on after the map is loaded don't yield a pop up window.
STATUS - Fixed with ArcGIS Online 3.7 update.
ArcGIS Online update 3.7 was released on March 2nd 2015.
