I am trying to update some fields on a certain feature set based on possibly sum or mean statistics from an associated feature set data. Doing this using the summary toolset does not seem to update as the field data is modified.
i.e. I used the analysis toolbox and created sum statistics on the first feature set. This I then linked to a field on the second feature set. The problem I have is that when the map is collecting live data on ArcGIS Online, the field data based on statistics does not update .
Any good way of doing this ?
If you have your own ArcGIS server (SQL database backend) you can use for data storage you achieve this using a database "view". No idea for ArcGIS Online hosted data sorry!
