'ApplyEdits' with one 'adds' fail when SQL server table have a FOREIGN KEY
5810
01-07-2015 04:16 AM
GertConradie
Hi
I have a REST (FeatureServer) service that I make an 'ApplyEdits' call to. It only succeeds if I remove an existing FK constraint on one of my columns.
When the FK is applied, the service request fail and supply a code 1060 and a "Rowbuffer creation failed." error. (In the logs available in the ArcGIS server administrator it becomes more clear what the internal SQL error was.)
Is there a work-around for that? Would be much appreciated.
Full scripts for my SQL tables attached.
Small snippet below:
-- Unless this FK constraint is removed, an ESRI Feature Service 'ApplyEdits' with the following 'adds' fail:
-- [{"geometry":{"x":97655.99152462519,"y":367271.9541849444,"spatialReference":{"wkid":29903,"latestWkid":29903}},"attributes":{"Label":"blablabla","SpecificFeatureTypeId":2,"PlanId":1}}]
ALTER TABLE [dbo].[PlanSpecificFeatures]  WITH CHECK ADD  CONSTRAINT [FK_PlanSpecificFeatures_SpecificFeatureType] FOREIGN KEY([SpecificFeatureTypeId])
REFERENCES [dbo].[SpecificFeatureType] ([SpecificFeatureTypeId])
GO
ALTER TABLE [dbo].[PlanSpecificFeatures] CHECK CONSTRAINT [FK_PlanSpecificFeatures_SpecificFeatureType]
GO
GertConradie
I got the fix/workaround:
You need to set the identity seed value of the 'master' table that you have a relationship with to start with '0' instead of the default '1'
I assume ArcGIS first create a record with the default int/string values and then update the attributes afterwards. (Might be problematic on a database with lots of integrity checks applied...)
CREATE TABLE [dbo].[SpecificFeatureType](
[SpecificFeatureTypeId] [int] IDENTITY(0,1) NOT NULL,
[Name] [varchar](50) NOT NULL,
CONSTRAINT [PK_SpecificFeatureType] PRIMARY KEY CLUSTERED
[SpecificFeatureTypeId] ASC
)WITH (PAD_INDEX = OFF, STATISTICS_NORECOMPUTE = OFF, IGNORE_DUP_KEY = OFF, ALLOW_ROW_LOCKS = ON, ALLOW_PAGE_LOCKS = ON) ON [PRIMARY]
) ON [PRIMARY]
GertConradie
Note that the integer value that I use in my request is a valid value that satisfy normal TSQL insert scripts when the FK is applied.
GertConradie
) ON [PRIMARY]
