import arcpy import sys import os # Script to create Shapefiles of WP Infrastructure within a specified boundary # Define variables UserName = "n041871" Shapefile = r"S:\SupportServices\Meet\Arc Gis\Planning Refs\Canning\20150107_CTLE.shp" Suffix = "CTLE" #Build Path name for workspace SDEPre = "C:\Users" SDEPost = "\AppData\Roaming\ESRI\Desktop10.0\ArcCatalog\DynamicCredentials@GISR.sde" SDE= os.path.join(SDEPre,UserName+SDEPost) print "Using "+SDE+" as Geodatabase" arcpy.AddMessage("Using " + str(SDE)+ " as Geodatabase") arcpy.env.workspace = SDE arcpy.env.overwriteOutput = True #Define Layers to Clip #1. Transmission feature classes T330OH = os.path.join ("GISTRAN.Transmission", "GISTRAN.Trans_330kV_OH_Carrier") T330UG = os.path.join ("GISTRAN.Transmission", "GISTRAN.Trans_330kV_UG_Cable") T220OV = os.path.join ("GISTRAN.Transmission", "GISTRAN.Trans_220kV_OH_Carrier") T132OH = os.path.join ("GISTRAN.Transmission", "GISTRAN.Trans_132kV_OH_Carrier") T132UG = os.path.join ("GISTRAN.Transmission" , "GISTRAN.Trans_132kV_UG_Cable") T66OV = os.path.join ("GISTRAN.Transmission", "GISTRAN.Trans_66kV_OH_Carrier") T66UG = os.path.join ("GISTRAN.Transmission", "GISTRAN.Trans_66kV_UG_Cable") T33OH = os.path.join ("GISTRAN.Transmission", "GISTRAN.Trans_33kV_OH_Carrier") T33UG = os.path.join ("GISTRAN.Transmission", "GISTRAN.Trans_33kV_UG_Cable") TransStruc = os.path.join ("GISTRAN.Transmission", "GISTRAN.Trans_Structure") Substation = os.path.join ("GISTRAN.Transmission", "GISTRAN.Substation") #Group Transmission Values: Transmission = (T330OH, T330UG, T220OV, T132OH, T132UG, T66OV, T66UG, T33OH, T33UG, TransStruc, Substation) #2. Distrubution feature classes POLES = os.path.join("ARCFM.Structure", "ARCFM.Pole") HVOH = os.path.join("ARCFM.Distribution_HV", "ARCFM.Conductor_HV") HVUG = os.path.join("ARCFM.Distribution_HV", "ARCFM.Cable_HV") LVOH = os.path.join("ARCFM.Distribution_LV", "ARCFM.Conductor_LV") LVUG = os.path.join("ARCFM.Distribution_LV", "ARCFM.Cable_LV") #Group Distribution Values Distribution = (POLES, HVOH, HVUG, LVOH, LVUG) #Future Infrastructure Shapefiles ISubstation = r"S:\SupportServices\SPIDA Projects\Transmission\Sub-Regional Structure Planning\WP Future Infrastructure\Version 1\WP_New_Sub_stations_20130807.shp" ILine = r"S:\SupportServices\SPIDA Projects\Transmission\Sub-Regional Structure Planning\WP Future Infrastructure\Version 1\WP_New_Power_Lines_20130807.shp" #Group New Infrastructure NewI = (ISubstation, ILine) #Select Required LOCALITY arcpy.MakeFeatureLayer_management(Shapefile, "lyr") #Set Ouput Directory outputPath = "S:\\SupportServices\\SPIDA Projects\\Infrastructure Shapefiles\\Custom\\"+ str(Suffix) # Clip Transmission Feature Classes with LOCALITY Layer for StrucT in Transmission: basefileName = arcpy.Describe(StrucT).baseName.replace('.','_') + Suffix fileFormat= '.shp' finalDest = os.path.join(outputPath,basefileName+fileFormat) arcpy.Clip_analysis(StrucT,Shapefile,finalDest) print StrucT + "Shapefile Created" arcpy.AddMessage(str(StrucT)+" Shapefile Created") # Clip Distriution Feature Classes with LOCALITY Layer for StrucD in Distribution: basefileName = arcpy.Describe(StrucD).baseName.replace('.','_') + Suffix fileFormat= '.shp' finalDest = os.path.join(outputPath,basefileName+fileFormat) arcpy.Clip_analysis(StrucD,Shapefile,finalDest) print StrucD + " Shapefile created" arcpy.AddMessage(str(StrucD)+" Shapefile Created") #Clip New Infrastructure for Struc in NewI: if not os.path.exists(outputPath):os.makedirs(outputPath) basefileName = arcpy.Describe(Struc).baseName.replace('.','_') + Suffix fileFormat= '.shp' finalDest = os.path.join(outputPath,basefileName+fileFormat) arcpy.Clip_analysis(Struc,Shapefile,finalDest) print Struc + " Shapefile created" arcpy.AddMessage(str(Struc)+" Shapefile Created") #Find empty shapefiles and delete them arcpy.env.workspace = outputPath shapefiles = arcpy.ListFeatureClasses() for shapefile in shapefiles: layerName = arcpy.Describe(shapefile).baseName arcpy.AddMessage(layerName) arcpy.MakeFeatureLayer_management (shapefile, layerName) arcpy.AddMessage(arcpy.GetCount_management(layerName).getOutput(0)) if int(arcpy.GetCount_management(layerName).getOutput(0)) == 0: arcpy.Delete_management(shapefile) print shapefile + " deleted" arcpy.AddMessage(str(shapefile)+" Deleted") print "All empty shapefiles have been deleted" arcpy.AddMessage("All empty shapefiles have been deleted") print "process complete"
I am getting the following error:
File "S:\SupportServices\Meet\Arc Gis\Scripts\WP_Infrastructure_Shapefile_Cut.py", line 71, in <module>
arcpy.Clip_analysis(StrucT,"lyr",finalDest)
File "c:\Program Files (x86)\ArcGIS\Desktop10.0\ArcPy\arcpy\analysis.py", line 55, in Clip
raise e
ExecuteError: ERROR 000210: Cannot create output S:\SupportServices\SPIDA Projects\Infrastructure Shapefiles\Custom\CTLE\GISTRAN_Trans_330kV_OH_CarrierCTLE.shp
Failed to execute (Clip).
I can't spot anything immediately obvious about the output path. If you search desktop help the error code states:
The output cannot be created. Potential reasons include data locking, an incorrect path, and limited access rights.
Confirm that the data is not locked by another user or application and that you have full rights to the workspace being used. Check to make sure that the path to the data is correct (check for typos in the folder path). Try creating the output in a new location.
I would start with say writing to a local c:\temp to confirm that its not a write permissions issues, if that works it would suggest the data has an issue. Try running the clip tool by itself with those datasets to see if the error occurs then?
