AnsweredAssumed Answered
Points to Line skipping vertices
Question asked by megie91 on Jan 5, 2015
Latest reply on Jan 16, 2015 by dlee-esristaff
I am working with the Points to Line tool within Modelbuilder.  The output of the tool always skips points from the points file when creating the vertices for the resulting line file.  I don't understand what the problem is because the Points to Line tool works perfectly outside of Modelbuilder (without any adjustments to the environments) by creating line vertices at each point from the point file.  I have tried using both default environment settings in Modelbuilder and adjusted environment settings, but nothing is resolving this issue.
Can anyone provide any possible explanations or resolutions?
Here is a screenshot of the output.  As you can see there is a point near the bend that has been skipped as a vertice in the line.
Outcomes
