AnsweredAssumed Answered
Extremely long wait when importing an .mxd into ArcGIS Pro...
Question asked by JohnReese on Jan 5, 2015
Latest reply on Jan 6, 2015 by JohnReese
I have imported muplitple .mxd files into ArcGIS Pro and on average, it takes 25-30 minutes to import and load the layers. My geodatabase connection has already been created and everything seems to be in working order. After the initial load time, everything works and seems to operate as expected with little to no delay.
The geodatabase being used as the data source is on an Oracle platform and I have the 64-bit client preceding the 32-bit client within the path, separated with a semi-colon.
I can't determine what, if anything I am doing wrong. However, I'm sure there is something I'm missing and I am curious if anyone else has encountered the same issue and has figured out what was causing the delay?
Any help would be appreciated. Thank you!
Outcomes
