View feature symbol
4797
8
01-04-2015 09:41 PM
BillKorbholz
This seems like a simple operation, but I just can't put the pieces together. I'm trying to view the symbol (it happens to be a simple fill symbol) associated with a feature (it happens to use unique value symbology). In other words, I want to construct a UniqueValueRenderer that will tell me what the symbology of this feature is.
BillKorbholz
Thanks to everyone who tried to help me with this. I finally stumbled over what I needed. VB.Net code fragment:
Dim pLayer As ESRI.ArcGIS.Carto.ILayer
Dim pFeatureLayer As ESRI.ArcGIS.Carto.IFeatureLayer
Dim pGFL As ESRI.ArcGIS.Carto.IGeoFeatureLayer ' This was the missing piece
Dim pUniqueRenderer As ESRI.ArcGIS.Carto.IUniqueValueRenderer
Dim pSymbol as ESRI.ArcGIS.Display.ISymbol
pLayer = ...
pFeatureLayer = pLayer
pGFL = pFeatureLayer
pUniqueRenderer = pGFL.Renderer
pSymbol = pUniqueRenderer.Symbol(pUniqueRenderer.Value(n))
BillKorbholz
I forgot to mention the environment: ArcGIS 10.3 with .Net SDK.
AnttiKajanus1
Occasional Contributor III
Hey,
Depending on the scenario you can use create Swatches‌ from the symbol to create image from it (provide geometry type as a parameter) or check Legend ‌and SymbolDisplay‌ controls. If you can tell me a bit more on the scenario, i might be able to help a bit more.
dotMorten_esri
Esri Notable Contributor
You can pass the feature into the renderer to get the symbol. Ex:
    Symbol symbol = myUniqueValueRenderer.GetSymbol(myFeature);
    ImageSource swatch = await symbol.CreateSwatchAsync();
BillKorbholz
Thanks for the reply, Morten. But here is my basic problem: I don't know how to create the unique value renderer in the first place. If I could do that, then getting the symbol would be quite straightforward. There has to be some combination of casts that will allow me to create a UVR for this feature set. Or maybe you're suggesting that I use something like a static UVR?
DominiqueBroux
Esri Frequent Contributor
There is a UniqueValueRenderer sample in the SDK that demonstrates how to build a UniqueValueRenderer by code.
Basically:
  - instantiate a UniqueValueRenderer object
  - set the Fields collection with the fields that participate to the renderer
  - set the Infos collection with the set of { values, symbol}
BillKorbholz
Thanks for replying, Dominique. I don't think I've been clear regarding what I want to do. I want to see what the current symbol is associated with a feature. I don't want to change it. So I can't follow the SDK example, since it requires me to know the symbol associated with each value. That is exactly what I am trying to discover.
Looking at the ArcMap user interface, I can see each symbol associated with each value of my feature set. I just want to do the same in code.
BillKorbholz
pLayer = ...
dotMorten_esri
Note: The above code is for ArcObjects, and not code for the ArcGIS Runtime .NET SDK - that probably explains a lot of the confusion.
