Arc Hydro: Batch Subwatershed Delineation
6778
5
01-06-2015 02:09 PM
PeterWilson
Occasional Contributor III
I've recently upgraded my Arc Hydro installation from 10.2.0.40 to 10.2.0.85 and my model stopped working where "Batch Subwatershed Delineation" was inserted. The output parameter for SubwatershedPoint  seems to be affected with the following error message: "Error 000735 Configuration for out_subwatershedpoint_features cannot be found in the configuration. : Value is required. The parameter is usually automatically populated with the string variable "SubwatershedPoint" and the output is saved to the output File Geodatabase Feature Dataset. I've tried installing previous versions as far back as 10.2.0.55 and the error message still persists. As soon as I re-install 10.2.0.40 the error message dissappears. Unnfortunately I need to be able to use the newer version due to changes that have been made. If anyone can assist in resoloving the following, it will truly be appreicated. I've attached a jpeg of the Batch Subwatershed Delineation with the error message for BatchSubwatershedPoint.
Regards
Peter Wilson
ChristineDartiguenave
Peter,
This is fixed in versions 10.2.0.94/10.3.0.2.
Christine
AlexanderMa
I actually have the same problem on my end. I tried adding a string variable (i.e. "test", "SubwatershedPoint", etc.) and would run this tool in ModelBuilder. However, I'm met with the error, below. I'm stuck on the step to create Subwatersheds yet the Help does not provide any information on what parameters to put in the field. My computer specs are shown below. archydro‌ esri help‌ water resources‌ modelbuilder‌ arc objects‌ batch_subwatershed_delineation‌
Windows 7 Professional 64-bit (6.1, Build 7601)
Intel Xeon CPU Quad Core 2.80 GHz
12 gb of RAM
NVIDIA Quadro FX 580
Start Time: Fri Jan 16 16:47:44 2015
Object reference not set to an instance of an object.
Failed to execute (Batch Subwatershed Delineation).
Failed at Fri Jan 16 16:47:44 2015 (Elapsed Time: 0.45 seconds)
PeterWilson
Hi Alexander
I've not been able to resolve the following as of yet. I emailed ESRI, but they have not been able to replicate the error from their side. I've reverted to a previous version of Arc Hydro 10.2.0.40, which has resolved the Subwatershed bug.
Hope the following helps you
Regards
Peter Wilson
AlexanderMa
Hi Peter,
Thanks for replying so promptly! I'm currently looking on the ESRI ArcHydro ftp site (https://mft.esri.com/) and I don't see the v.10.2.0.40 install folder located on there anymore. The current version of ArcHydro that they have on the FTP is shown in the screenshot below, of my installed programs.
I'm thinking of just downgrading each ArcHydro version until it works; however that sounds really tedious. Any other suggestions are greatly appreciated!
Peter,
Christine
PeterWilson
Hi Christine
Thanks so much for the following update
Regards
Peter Wilson
