Coordinates
4522
5
01-03-2015 07:31 AM
IvanBodnar
I'm new at gis. I'm using Arcgis 10.2.2 and trying to geocode some addresses. I used a geocoding service which gave the coordinates in this format:
POINT(102778.307715144 105888.168842117)
I don't know how to handle that, so I tried the Convert Coordinate Notation tool, but it throws me an error: output file already exists and it cannot be overwritten (the issue must be other since the file doesn't really exists). By the way, I tried to convert that to GCS_WGS_1984, wich is the coordinate system I always use.
Any clue? Thanks
XanderBakker
Esri Esteemed Contributor
If you use the Find locations tool, it will return the geocoding result in the coordinate system you have defined in you data frame. You may have to be more specific as to which geocoding service you are using. Some support that the result is projected to a different coordinate system.
The POINT you received is in projected coordinates. However, since you didn't specify the location nor the projection used it will be almost impossible to advice you how to project the result to WGS 1984. So, please provide some more details...
MelitaKennedy
Esri Notable Contributor
Also asked (and answered) on gis.SE.
The data is using a city of Buenos Aires coordinate reference system:
GeoCRS (datum): Campo Inchauspe
Projection: Transverse Mercator
Central Meridian: -58.4627
Latitude of Origin: -34.6297166
Scale Factor: 0.999998
False Easting: 100000.0 m
False Northing: 100000.0 m
Unit: Meter
Melita
IvanBodnar
SOLVED:
I ran into this explanation: http://blogs.esri.com/esri/supportcenter/2010/10/29/haunted-by-geocoding-brew-up-something-new-with-...
So I downloaded the locator styles from 9.3 and followed the instructions to add them. Then I created a 9.3 style locator, and it worked as a charm. I guess it's a 10.2.2 bug.
Thank you all
XanderBakker
Glad you made it work.
TimWitt2
Don't forget to mark the correct answer.
