AnsweredAssumed Answered
Delete Polygon Intersection!!
Question asked by ilyass on Dec 30, 2014
Latest reply on Jan 19, 2015 by ilyass
Hi All,
The objective is to create a code that allow me to delete polygons if they intersect.
Scenario:
- Keep the first one.
- Check the second one if intersect delete the second if not keep it.
- Check the third one if intersect delete if not keep it.
I create a code in Javascript using service network area for arcgis online that you can test the result (Working but not deleting the intersection) the problem is i don't know how to check the intersection and deleted from the list if someone can help i will be very greatful.
Below the code:
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
  <title>Dispatch Algorithm Implementation</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css">
  <style>
    body,html,#main{margin:0;padding:0;height:100%;width:100%;}
  </style>
  <script>var dojoConfig = { parseOnLoad: true };</script>
  <script src="http://js.arcgis.com/3.9/"></script>
  <script>
    dojo.require("esri.map");
    dojo.require("esri.tasks.servicearea");
    dojo.require("dijit.dijit");
    dojo.require("dijit.layout.BorderContainer");
    dojo.require("dijit.layout.ContentPane");
    dojo.require("dijit.form.HorizontalSlider");
    dojo.require("dijit.form.HorizontalRuleLabels");
    dojo.require("dijit.form.HorizontalRule");
  dojo.require("dijit.form.Button");
  dojo.require("esri.graphic");
  dojo.require("esri.tasks.geometry");
  dojo.require("esri.layers.graphics");
  dojo.require("esri.Color");
    var map, serviceAreaTask, params, clickpoint, gsvc;
    function init() {
      esri.config.defaults.io.proxyUrl = "/proxy";
      map = new esri.Map("map", {
        basemap: "streets",
        center: [-122.447, 37.781],
        zoom: 14
      params = new esri.tasks.ServiceAreaParameters();
      params.defaultBreaks= [1];
      params.outSpatialReference = map.spatialReference;
      params.returnFacilities = true;
      serviceAreaTask = new esri.tasks.ServiceAreaTask("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Network/USA/NAServer/Service Area");
   gsvc = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
      dojo.connect(dijit.byId("hslider"), "onChange", updateHorizontalLabel);
      updateHorizontalLabel();
    // Create function that updates label when changed
    function updateHorizontalLabel() {
      // Get access to nodes/widgets we need to get/set values
      var hSlider = dijit.byId("hslider");
      var label = dojo.byId("decValue");
      // Update label
      label.innerHTML = hSlider.get("value");
      params.defaultBreaks = [hSlider.value/60];
     // if (typeof clickpoint != 'undefined') {
     //   AddDT(clickpoint);
    //Clears DTP
      function ClearDTP() {
  map.graphics.clear();
    function AddDTP() {
      map.graphics.clear(); //clear existing graphics
      //define the symbology used to display the results and input point
      var pointSymbol = new esri.symbol.PictureMarkerSymbol({
        "angle":0,
        "xoffset":0,
        "yoffset":10,
        "type":"esriPMS",
        "url":"http://icons.iconarchive.com/icons/aha-soft/standard-transport/256/police-car-icon.png",
        "contentType":"image/png",
        "width":30,
        "height":30
    var m_mapPoint = [];
  m_mapPoint[1] = new esri.geometry.Point([-122.447, 37.781],new esri.SpatialReference({ wkid:4326 }));
  m_mapPoint[2] = new esri.geometry.Point([-122.457, 37.791],new esri.SpatialReference({ wkid:4326 }));
  m_mapPoint[3] = new esri.geometry.Point([-122.450, 37.785],new esri.SpatialReference({ wkid:4326 }));
  m_mapPoint[4] = new esri.geometry.Point([-122.452, 37.775],new esri.SpatialReference({ wkid:4326 }));
  m_mapPoint[5] = new esri.geometry.Point([-122.452, 37.791],new esri.SpatialReference({ wkid:4326 }));
  m_mapPoint[6] = new esri.geometry.Point([-122.450, 37.777],new esri.SpatialReference({ wkid:4326 }));
  m_mapPoint[7] = new esri.geometry.Point([-122.470, 37.777],new esri.SpatialReference({ wkid:4326 }));
      var location1 = new esri.Graphic(m_mapPoint[1],pointSymbol);
   var location2 = new esri.Graphic(m_mapPoint[2],pointSymbol);
   var location3 = new esri.Graphic(m_mapPoint[3],pointSymbol);
   var location4 = new esri.Graphic(m_mapPoint[4],pointSymbol);
   var location5 = new esri.Graphic(m_mapPoint[5],pointSymbol);
   var location6 = new esri.Graphic(m_mapPoint[6],pointSymbol);
   var location7 = new esri.Graphic(m_mapPoint[7],pointSymbol);
      map.graphics.add(location1);
   map.graphics.add(location2);
   map.graphics.add(location3);
   map.graphics.add(location4);
   map.graphics.add(location5);
   map.graphics.add(location6);
   map.graphics.add(location7);
      var features = [];
      features.push(location1);
   features.push(location2);
   features.push(location3);
   features.push(location4);
   features.push(location5);
   features.push(location6);
   features.push(location7);
      var facilities = new esri.tasks.FeatureSet();
      facilities.features = features;
      params.facilities = facilities;
      //solve
      serviceAreaTask.solve(params,function(solveResult){
        var result = solveResult;
        var serviceAreaSymbol = new esri.symbol.SimpleFillSymbol(
          esri.symbol.SimpleFillSymbol.STYLE_SOLID,
          new esri.symbol.SimpleLineSymbol(
            esri.symbol.SimpleLineSymbol.STYLE_SOLID,
            new dojo.Color([232,104,80]), 2
          new dojo.Color([232,104,80,0.25])
        var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID,  new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
              new dojo.Color([232,104,80]), 2),new dojo.Color([232,104,80,0.25]));
  var polys = solveResult.serviceAreaPolygons;
  var index=0;
  // Filters all the polygons that intersect each other
  filterIntersections(polys, index);
  // Put the remaining polygons on the map
  dojo.forEach(polys, function(poly){
  poly.setSymbol(polygonSymbol);
  map.graphics.add(poly);
      }, function(err){
        console.log(err.message);
  function filterIntersections(polys, index)
  var polysIntersect = [];
  for (var j=index+1; j<polys.length; j++)
  polysIntersect.push(polys[j].geometry);
  if(polysIntersect.length == 0)
  // End of filtering
  return;
  // Call intersect service
  gsvc.intersect(polysIntersect, polys[index].geometry, function(obj){
  console.log(obj);
Delete from polys list all polygons that intersect with polys[index]
when we delete a polygon from polys -> index--;
this part here i don't know how to do ??
  // Next polygon
  index++;
  }, function(err){
    dojo.ready(init);
  </script>
</head>
<body class="claro">
  <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%;height:100%;margin:0px;">
    <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'">
      <b>Choose your threshold to find the appropriate dispatch:</b>
      <div style="width: 360px; margin: 10px">
        <!-- create rules and labels above horizontal slider -->
        <ol data-dojo-type="dijit.form.HorizontalRuleLabels"
          data-dojo-props="
            container: 'topDecoration',
            style: 'height: 1.2em; font-weight: bold; margin: 0 12px;'">
          <li>0</li>
          <li>0:20</li>
          <li>0:40</li>
          <li>1:00</li>
          <li>1:20</li>
   <li>1:40</li>
   <li>2:00</li>
        </ol>
        <div data-dojo-type="dijit.form.HorizontalRule"
          data-dojo-props="
            count: 7,
            style: 'height: 5px; margin: 0 12px;'">
        </div>
        <input id="hslider" value="60" type="range"
          data-dojo-type="dijit.form.HorizontalSlider"
          data-dojo-props="
            minimum: 0,
            maximum: 120,
            showButtons: false,
            discreteValues: 25">
        <div style="padding-top: 10px; text-align: center;">Travel time: <strong id="decValue"></strong> Seconds</div>
  <br><br>
  <label class="form_col" for="NumberPC">Please Enter a Number of Patrol Car:</label>
        <input name="NumberPC" id="NumberPC" type="text" size="10" />
  <br><br>
  <label class="form_col" for="zone">Zone :</label>
      <select name="zone" id="zone">
        <option value="none">Select your zone</option>
        <option value="z1">zone 1</option>
        <option value="z2">zone 2</option>
        <option value="z3">zone 3</option>
      </select>
  <br><br>
  <button onclick="AddDTP();">Dispatch</button>
  <button onclick="ClearDTP();">Clear Dispatch</button>
      </div>
    </div>
    <div id="map" dojotype="dijit.layout.ContentPane" data-dojo-props="region:'center'"></div>
  </div>
</body>
</html>
Outcomes
