Dear Gurus!
In some tasks you must specify the LayerIds. How to define it when I know it's name?
For example in Identify task I use code:
ESRI.ArcGIS.Client.Tasks.IdentifyParameters identifyParams = new IdentifyParameters() { Geometry = clickPoint, MapExtent = Map.Extent, Width = (int)Map.ActualWidth, Height = (int)Map.ActualHeight, LayerOption = LayerOption.all, SpatialReference = Map.SpatialReference , Tolerance = 30 }; identifyParams.LayerIds.Add(2); identifyParams.LayerIds.Add(3);
But sometimes it is necessary to change the sequence of layers before the next publication.
I have find next solution - http://help.arcgis.com/en/webapi/wpf/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.ArcGISDynamicMapSe...
