Mann Kendall Test
7964
12
12-27-2014 01:09 AM
AhsanAbbas
New Contributor III
Hello Guys, I need to perform Mann Kendall test on 5 series raster data yearly basis, from 2007 to 2011.
if need to iterate pixel by pixel on raster cell values for calculating the sign. How can i do it... Below is code but i have problem with numpy...
import arcpy
import numpy
from arcpy import env
env.workspace = r"D:\PythonProject\Data"
rasterlist = arcpy.ListRasters()
for raster in rasterlist:
    print raster
n = len(rasterlist)
pairs = (n * ( n - 1)) / 2
print "Pairs to be formed: ", pairs
def pairsRasters(raster1, raster2):
    print raster1, " - ", raster2
    inRas1 = arcpy.Raster(raster1)
    lowerLeft1 = arcpy.Point(inRas1.extent.XMin,inRas1.extent.YMin)
    #cellSize = inRas.meanCellWidth
    my_array1 = arcpy.RasterToNumPyArray(inRas1,nodata_to_value=0)
    inRas2 = arcpy.Raster(raster2)
    lowerLeft2 = arcpy.Point(inRas2.extent.XMin,inRas2.extent.YMin)
    my_array2 = arcpy.RasterToNumPyArray(inRas2,nodata_to_value=0)
for current in reversed(rasterlist):
    for previous in rasterlist:
        if current == previous:
            pass
        elif current > previous:
            pairsRasters(current, previous)
        else:
            pass
Suppose the two raster of similar extent, i need to calculate difference, if it's greater than 1 the value store in output raster would be 1, if less than 1 the value would be -1 and else zero. How can i iterate on pixel by pixel of two rasters. so i can save it into new raster. That's it..
Column 1
Column 2Column 3Column 4Column 5
50259810298
1229810210100
5766922110
9845255959
5898173154
Message was edited by: Ahsan Abbas
DanPatterson_Retired
try the following to see if this is what you want
3 arrays with differing values and sign
>>> a
array([ 6.,  5.,  5.,  3.,  1.,  1.])
>>> b
array([ 1., -2.,  3.,  4.,  5., -6.])
>>> c
array([-3., -2., -1.,  4., -5., -6.])
>>> np.sign(b-a)
array([-1., -1., -1.,  1.,  1., -1.])
>>> np.sign(c-b)
array([-1.,  0., -1.,  0., -1.,  0.])
>>> np.sign(a-c)
array([ 1.,  1.,  1., -1.,  1.,  1.])
can you show a sample of your inputs and your output...It seems you are comparing the whole rasters once without any just checking to see whether they are the same.
Also see the Mann-Kendall implementation here
Not familiar with the test that much, but if you are only interested in the signs then you can look at this example
>>> a
array([[ 1.,  2.],
       [ 3.,  4.],
       [ 5.,  6.]])
>>> b
array([[ 1., -2.],
       [ 3.,  4.],
       [ 5., -6.]])
>>> sign_ab = np.sign(a-b)
>>> sign_ab
array([[ 0.,  1.],
       [ 0.,  0.],
       [ 0.,  1.]])
You can iterate from there is you like to see if the sign changes through a sequence of rasters (oh yes, 0 means the sign didn't change 1, it did)
AhsanAbbas
New Contributor III
what would be value if it's (5 - 9), is it -1 or -4 ?
>>> a
>>> b
>>> c
>>> np.sign(b-a)
>>> np.sign(c-b)
>>> np.sign(a-c)
AhsanAbbas
New Contributor III
Thanks Dan Patterson‌, for help, i have bug in my program, but i find it successfully...
Ahsan... Good! ...you should post the result the result so others may find it
AhsanAbbas
New Contributor III
I will post it when it will be complete, half done yet...
The half code....Dan Patterson‌, please check it...
import arcpy
import numpy
import numpy as np
    print raster
n = len(rasterlist)
    desc1 = arcpy.Describe(raster1)
    desc2 = arcpy.Describe(raster2)
    nameRaster = desc1.basename + " - " + desc2.basename
    #print nameRaster
    array1 = arcpy.RasterToNumPyArray(raster1,nodata_to_value=0)
    array2 = arcpy.RasterToNumPyArray(raster2,nodata_to_value=0)
    #print "\n ", array1.shape
    # to see how many dimension the array has
    (height, width) = array1.shape
    newRaster = numpy.zeros([height, width])
    for row in range(height):
        for col in range(width):
            #print "Row, Column: ", row, col
            #print float(array2[row][col]), float(array1[row][col])
            #print (float(array2[row][col]) - float(array1[row][col]))
            newRaster[row][col] = np.sign(float(array2[row][col]) - float(array1[row][col]))
    finalRaster = arcpy.NumPyArrayToRaster(newRaster)
    outname = "D:/PythonProject/Outputs/" + (nameRaster + ".img")
    #arcpy.CopyRaster_management(name, outname ,"DEFAULTS","0","9","","","8_BIT_UNSIGNED")
    finalRaster.save(outname)
            pass
        else:
            pass
XanderBakker
Esri Esteemed Contributor
Although I have no idea on what the Mann Kendall Test will get you, it seems that the code below works.
import arcpy
import numpy
import os
def main():
    ws_in = r"D:\PythonProject\Data"
    ws_out = r"D:\PythonProject\Outputs"
    arcpy.env.workspace = ws_in
    n = len(rasterlist)
    print "Pairs to be formed: {0}".format(pairs)
    for i in rasterlist:
        for j in rasterlist[rasterlist.index(i)+1:]:
            print i, j
            pairsRasters(i, j, ws_out)
def pairsRasters(raster1, raster2, ws):
    nameRaster = "{0}_{1}.img".format(desc1.basename, desc2.basename)
    print nameRaster
    newRaster = numpy.sign(array2 - array1)
    outname = os.path.join(ws, nameRaster)
if __name__ == '__main__':
    main()
You may want to check the names of the input rasters. If they have extensions, you may want to strip them to create a valid output name.
AhsanAbbas
New Contributor III
Xander Bakker ,The Menn Kendall test is non-parametric test, use to find the trend of data either increasing, decreasing or remains same. I just want to find the trend, And what is wrong with my code is it not understand able ?
I also wants to add these save rasters to one raster, and assign the projection of original raster, Where should i change the code ?
