In the example below, a proxy file is used and it is able to skip user signin step:
https://developers.arcgis.com/javascript/jssamples/geoenrichment_infographic.html
http://developers.arcgis.com/javascript/samples/analysis_summarizenearby/
However, the sign in window always shows up using the same Proxy file.
Has anybody successfully used proxy and app login to integrate the following analysis widget,
in your application?
thanks,
Jiehua
From ESRI Inc.:
"Analysis tools need to be authenticated to determine user privilege ( Publisher, other analysis privilege) I don’t think this can be bypassed using s-proxy like in geonenrichment. "
We definitely need to know this reason behind....
Thanks.
