Hello Everybody,
I have a GRID Raster with 8 Bit Integer Cell Values ranging from 1 to 4. I would like to change the symbology using Line Fill and/or Marker Fill accessed via "Symbol Selector" -> "Edit Symbol" -> Type: Line Fill Symbol".
This doenst seem to work: The the values are simply filled with the color I chose the lines or points to be in. Is "Line Fill" simply not possible with GRID Raster data or am I doing something wrong?
Thanks in advance!
Solved! Go to Solution.
When symbolizing a raster only the cell colors can be defined.
You could convert your raster to polygons and apply the symbology you want.
Thanks for the answer! It's kind of what I expected, I was just confused since the possibility of setting "line fill" was there in the first place..
