Why aren't my layers drawing correctly?
1309
12-12-2014 02:40 PM
ChrisSergent
Regular Contributor III
I added two new layers, activeWeedCases and activeCases and they do not draw correctly. One layer appears to be missing until you move the map some. And both layers cover the lBaseLayer that has the address number on them even though I added that layer last. Is something wrong with my code?
/// <reference path="esri-leaflet.min.js" />
/// <reference path="leaflet.js" />
/// <reference path="jquery-1.9.1.js" />
/// <reference path="jquery-ui-1.10.3.custom.min.js" />
/// <reference path="jquery.greybox2.js" />
/// <reference path="jquery.ui.touch-punch.js" />
// If JavaScript appears not to run, a line of code may not work properly
var map = L.map('mapSection').setView([39.861, -88.951], 13);
//ADD LEAFLET.USERMARKER PLUGIN
var marker = null;
map.on("locationfound", function (location) {
    if (!marker)
        marker = L.userMarker(location.latlng, { pulsing: true }).addTo(map);
    marker.setLatLng(location.latlng);
    marker.setAccuracy(location.accuracy);
map.locate({
    watch: false, //This makes the locator move as the user changes location. Set to false to disable.
    locate: true, // Set to true to locate the current location of the user
    setView: true,
    maxZoom: 20,
    minZoom: 18,
    enableHighAccuracy: true,
    inertia: true
//END LEAFLET.USERMARKER PLUGIN
// Esri Image Layer
var imageLayer = L.esri.basemapLayer("Imagery");
//// Address Points, Streets, and Corporate Boundary
var lBaseLayer = L.esri.dynamicMapLayer("http://maps.decaturil.gov/arcgis/rest/services/Base/MapServer");
// Parcel Layer identified in the application - only Municipal parcels are available in this web service
var parcels = L.esri.dynamicMapLayer("http://maps.decaturil.gov/arcgis/rest/services/Parcels/MapServer");
// Parcels with no PINs
//var missingPins = L.esri.dynamicMapLayer("http://maps.decaturil.gov/arcgis/rest/services/MissingAddressCodes/MapServer");
var activeCases = L.esri.dynamicMapLayer("http://maps.decaturil.gov/arcgis/rest/services/Internal/activececases/MapServer");
var activeWeedCases = L.esri.dynamicMapLayer("http://maps.decaturil.gov/arcgis/rest/services/Internal/ActiveWeedCases/MapServer");
// Add featureLayer for drawing
var parcelsF = L.esri.featureLayer("http://maps.decaturil.gov/arcgis/rest/services/Parcels/MapServer/0", {
    where: '1=0',
    style: function (feature) {
        // My color came from here: http://www.colorhexa.com/70ca49
        return { color: "#f5f505", weight: 5 };
    onEachFeature: function (feature, layer) {
        //layer.bindPopup(L.Util.template(template, feature.properties));
}).addTo(map);
map.addLayer(imageLayer);
// I want to highlight the select parcel when I click on this layer
map.addLayer(activeWeedCases);
map.addLayer(activeCases);
map.addLayer(parcels);
map.addLayer(lBaseLayer);
//map.addLayer(missingPins);
// This is Esri JSAPI code; the first line determines how to get the name of the layer and the second is acquire the quantity of layers
//alert(dynamicMapServiceLayer.layerInfos[5].name);
//alert((dynamicMapServiceLayer.visibleLayers.length) + 1);
// Identify Dynamic Map Features
map.on("click", function (e) {
    parcels.identify(e.latlng, function (data) {
        jQuery("#sideBarContent").accordion("option", "active", 0);
        //alert(data.results[0].layerName); //This will identify a layer name in leaflet
        document.forms["frmMap"].elements["txtPin"].value = data.results[0].attributes.PIN;
        document.forms["frmMap"].elements["txtAddress"].value = data.results[0].attributes.SITEADDRESS;
        document.forms["frmMap"].elements["txtPrimaryName"].value = data.results[0].attributes.PRIMARYNAME;
        document.forms["frmMap"].elements["txtPrimaryAddress"].value = data.results[0].attributes.PRIMARYADDRESS;
        document.forms["frmMap"].elements["txtLegalDescription"].value = data.results[0].attributes.LEGALDESCRIPTION;
        document.getElementById("btnStartCase").disabled = false;
        document.getElementById("lblCaseCreated").innerHTML = '';
        document.getElementById("btnCreateCase").disabled = true;
        // returns an array of results, just grab the first one
        var result = data.results[0];
        console.debug(data, result);
        if (result) {
            var parcelnum = result.attributes.PARCELNUMBER;
            highlightLayer(parcelnum);
/* Enables Sidebar to be draggable */
jQuery(function () {
    jQuery("#sideBar").draggable();
/* The accordion allows sections to expand/collapse which show or hide each section */
    jQuery("#sideBarTitle").accordion({
        collapsible: true,
        heightStyle: "content"
    jQuery("#sideBarContent").accordion({
// Expands/collapses the Ask for Assistance   Note: Setting active to false collapses section. Setting heightStyle to Content autosizes the height
    jQuery("#footerTitle").accordion({
        collapsible: true,
        heightStyle: "content",
        active: false
// Opens the greybox for the help page
jQuery(document).ready(function () {
    var gbOptions = {
        gbWidth: 600,
        gbHeight: 500,
        captionHeight: 22,
        ffMacFlash: true
    jQuery('#lnkHelp').greybox(gbOptions);
// Set active section of sidebar
// http://api.jqueryui.com/accordion/ - how to activate a certain panel in the accordion
function showAddCase() {
    jQuery("#sideBarContent").accordion("option", "active", 1);
// Set layer to be highlighted
function highlightLayer(value) {
    console.debug('highlight', value);
    parcelsF.setWhere("PARCELNUMBER = '" + value + "'");
Tags (1)
