AnsweredAssumed Answered
query builder
Question asked by mallikarjun016 on Dec 7, 2014
good morning , am doing a query builder and i need help regarding how to get fields and its  values in a table i referred the the following example but i need dynamically all fields .Simple Find
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Simple Find</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.2/js/dojo/dijit/themes/claro/claro.css">
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.2"></script>
    <script type="text/javascript">
      dojo.require("esri.map");
      dojo.require("esri.tasks.find");
      var find, params;
      function init() {
        find = new esri.tasks.FindTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/");
        params = new esri.tasks.FindParameters();
        params.layerIds = [2];
        params.searchFields = ["STATE_NAME","STATE_FIPS"];
      function doFind() {
        params.searchText = dojo.byId("searchText").value;
        find.execute(params, showResults);
      function showResults(results) {
        var result, attribs;
        var s = ["<table border=\"1\"><thead><tr style=\"background-color:#ccc;\"><td>State Name</td><td>FIPS</td><td>Population (1990)</td><td>Population (1999)</td></tr></thead><tbody id=\"states\">"];
        dojo.forEach(results,function(result){
          attribs = result.feature.attributes;
           s.push("<tr><td>" + attribs.STATE_NAME + "</td><td>" + attribs.STATE_FIPS + "</td><td>" + attribs.POP1990 + "</td><td>" + attribs.POP1999 + "</td></tr>");
        s.push("</tbody></table>");
        dojo.byId("tbl").innerHTML = s.join("");
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    Find by State Name or State FIPS: <input type="text" id="searchText" size="40" value="Kansas" />
    <input type="button" value="Find" onclick="doFind()" />
    <div id="tbl"></div>
  </body>
</html>
1) i have taken all layers in dropdown, when i selected particular layer its fields are displayed in listbox ,if i select any field and click the button and result should be in format of above program output. thanks in advance.
Outcomes
