Question
3296
11
12-09-2014 01:32 PM
LucyCourchaine
I am learning from the trial version,  is the lot min area and lot max area in acres?
by Anonymous User
Not applicable
All units in CE are meters, so
Length = meters
Area = meters squared
Volumes = meters cubed
Hooray for metric. Down with the dark side.
BenLeslie1
Occasional Contributor III
What about if your coord system is 'Raw data in feet' or another non-metric system?
LucyCourchaine
Ben,
I assume that the coord system that i am importing is adjusting to the metric system when i import it.  But to answer your question the raw data that I work with is in feet and acres, not meters.
LucyCourchaine
Is there a way to change the default through preferences or something to feet and acres?
BenLeslie1
I don't know about preference settings but if you're running the subdivision tool you can do that via python and build in a conversion factor.
LucyCourchaine
Ok, I haven't gotten to that tutorial yet so I will investigate. Thank you for your help!
MatthiasBuehler
Hey ..
There's no way to way to set different main units. Meters it is.
CGA is also meter based, e.g. extrude(1) extrudes 1 meter.
I highly recommend to use both CGA and Python only to convert attributes to meters and then work metric.
Cheers!
Matt
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
Garsdale Design Limited
matthias.buehler@garsdaledesign.co.uk
www.garsdaledesign.co.uk
LucyCourchaine
Ok, thank you
LucyCourchaine
Oh, i have another question, do you know if I can add geo location information to a print screen jpeg?  when i imported an aerial, it was not geo located, then imported a shapefile that was City Engine said they were to far apart.  How can I resolve that?
