AnsweredAssumed Answered
How can I use the editor widget on an iPad?
Question asked by csergent08 Champion on Dec 8, 2014
Latest reply on Dec 9, 2014 by csergent08
I want to be able to touch on the editor template chooser and then touch on an iPad to create a new point to edit. Is there a way to do this with this widget on an iPad?
Here is my current code that works on a pc:
<!DOCTYPE html>
<html>
    <head>
        <title>Decatur Graphics Editor</title>
        <meta http-equiv="content-type" content="text/html; charset=utf-8">
        <meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/soria/soria.css">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
        <style>
            html, body, #mapDiv
                padding:0;
                margin:0;
                height:100%;
                width:100%;
                position:absolute;
                z-index:0;
            /* Editor style begin */
            #templatePickerPane {
                width: 250px;
                height:260px;
                overflow: hidden;
                z-index:50;
                top:50%;
                right:0%;
                position:absolute;
            #panelHeader
                background-color: #92A661;
                border-bottom: solid 1px #92A860;
                color: #FFF;
                font-size: 18px;
                height: 50px;
                line-height: 22px;
                margin: 0;
                overflow: hidden;
                padding: 10px 10px 10px 10px;
            #editorDiv
                background-color:White;
                padding:10px;
              .esriEditor .templatePicker
                padding-bottom: 5px;
                padding-top: 5px;
                height: 120px;
                border-radius: 0px 0px 4px 4px;
                border: solid 1px #92A661;
              .dj_ie .infowindow .window .top .right .user .content, .dj_ie .simpleInfoWindow .content
                position: relative;
            /* Editor Style End */
            #closeEditor
                position:absolute;
                right:5%;
            #editor
                height:20px;
                width:20px;
                position:absolute;
                top:285px;
                left:20px;
                z-index:50;
                padding: 5px 6px 6px 6px;
                background-color:#f9f8f8;
                border-radius:5px;
                visibility:visible;
    </style>
        <script src="http://js.arcgis.com/3.11/" type="text/javascript"></script>
        <script type="text/javascript">
            var map;
            require(["esri/map", "esri/config",
                     "esri/geometry/Extent",
                     "esri/dijit/editing/Editor",
                     "esri/layers/ArcGISDynamicMapServiceLayer",
                     "esri/layers/ArcGISTiledMapServiceLayer",
                     "esri/layers/FeatureLayer",
                     "esri/SnappingManager",
                     "esri/tasks/GeometryService",
                     "esri/toolbars/draw",
                     "dojo/dom",
                     "dojo/keys",
                     "dojo/on",
                     "dojo/parser",
                     "dojo/_base/array",
                     "dojo/i18n!esri/nls/jsapi",
                     "dojo/dnd/Moveable",
                     "dojo/domReady!"], function (Map, esriConfig, Extent, Editor, ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer,
                                                  FeatureLayer, SnappingManager, GeometryService, Draw, dom, keys, on, parser, arrayUtils, i18n, Moveable
                         parser.parse();
                         //snapping is enabled for this sample - change the tooltip to reflect this
                         i18n.toolbars.draw.start += "<br/>Press <b>CTRL</b> to enable snapping";
                         i18n.toolbars.draw.addPoint += "<br/>Press <b>CTRL</b> to enable snapping";
                         /* The proxy comes before all references to web services */
                         /* Files required for security are proxy.config, web.config and proxy.ashx
                         - set security in Manager to Private, available to selected users and select Allow access to all users who are logged in
                         (Roles are not required)
                         The proxy section is defined on the ESRI sample. I have included it as
                         part of the documentation reads that the measuring will not work.
                         I thought that might be important.
                         // Proxy Definition Begin
                         //identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
                         //If this null or not available the project and lengths operation will not work.
                         // Otherwise it will do a http post to the proxy.
                         esriConfig.defaults.io.proxyUrl = "proxy.ashx";
                         esriConfig.defaults.io.alwaysUseProxy = true;
                         // Proxy Definition End
                         // declare geometry service
                         esriConfig.defaults.geometryService = new GeometryService("http://maps.decaturil.gov/arcgis/rest/services/Utilities/Geometry/GeometryServer");
                         // set custom extent
                         var initialExtent = new Extent({
                             "xmin": 777229.03,
                             "ymin": 1133467.92,
                             "xmax": 848340.14,
                             "ymax": 1185634.58,
                             "spatialReference": {
                                 "wkid": 3435
                         // create map and set slider style to small
                         map = new Map("mapDiv", {
                             showAttribution: false,
                             sliderStyle: "small",
                             extent: initialExtent,
                             logo:false
                         // Starts initEditing after the feature layer(s) have been added
                         map.on("layers-add-result", initEditing);
                         // add imagery
                         var tiled = new ArcGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
                         map.addLayer(tiled);
                         // set operational layers
                         var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", { "opacity": 0.5 });
                         // add operational layers
                         map.addLayer(operationalLayer);
                         // add point feature layer for editing
                         var pointFeatureLayer = new FeatureLayer("http://maps.decaturil.gov/arcgis/rest/services/Test/FeatureServer/0", {
                             mode: FeatureLayer.MODE_ONDEMAND,
                             outFields: ["*"]
                         map.addLayers([pointFeatureLayer]);
                         // sizes the edit window
                         map.infoWindow.resize(400, 300);
                         // settings for the editor widget
                         function initEditing(event) {
                             var featureLayerInfos = arrayUtils.map(event.layers, function (layer) {
                                 return {
                                     "featureLayer": layer.layer
                             var settings = {
                                 map: map,
                                 layerInfos: featureLayerInfos,
                                 toolbarVisible:true,
                                 enableUndoRedo :true,
                                 maxUndoOperations:20
                             var params = {
                                 settings: settings
                             var editorWidget = new Editor(params, 'editorDiv');
                             editorWidget.startup();
                             var options = { snapKey: keys.copyKey };
                             map.enableSnapping(options);
                         // Allow editor to move with mouse
                         on(Moveable(dom.byId("templatePickerPane")), "onmousedown", function () {
                             var dnd = new Moveable(dom.byId("templatePickerPane"));
                         // Hide editor
                         on(dom.byId("closeEditor"), "click", function () {
                             document.getElementById("templatePickerPane").style.visibility = 'hidden';
                         // Show Editor
                         on(dom.byId("showEditorWidget"), "click", function () {
                             document.getElementById("templatePickerPane").style.visibility = 'visible';
        </script>
    </head>
    <body class="soria">
      <div id="mapDiv">
        <div id="editor">
            <input type="image" id="showEditorWidget" src="images/edit.ico" alt="Editor" title="Editor" />
        </div>
       </div>
      <div id="templatePickerPane">
        <div id="panelHeader">
          <p>Default Editor     <input type="image" id="closeEditor" src="images/close.ico" alt="Close Editor" title="Close Editor" /></p>
        </div>
        <div id="editorDiv">
        </div>
      </div>
  </body>
</html>
Outcomes
