AnsweredAssumed Answered
Why won't my Table on Contents Widget Work?
Question asked by csergent08 Champion on Dec 5, 2014
Latest reply on Dec 10, 2014 by csergent08
@@@Sometimes my table of contents displays and sometimes it does not; why is this?
<!DOCTYPE html>
<html>
    <head>
        <title>Create a Map</title>
        <meta http-equiv="content-type" content="text/html; charset=utf-8">
        <meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/soria/soria.css">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
        <link href="agsjs/dijit/css/TOC.css" rel="stylesheet" type="text/css" />
        <style>
            html, body, #mapDiv
                padding:0;
                margin:0;
                height:100%;
                width:100%;
                overflow:hidden;
            #tocDiv
                z-index:50;
                position:absolute;
                top:0%;
                left:0%;
                width:300px;
                height:auto;
                background-color:White;
            #scaleDiv .agsjsTOCOutOfScale {
              display:none;
        </style>
        <script src="http://js.arcgis.com/3.11/"></script>
        <script src="agsjs/dijit/TOC.js" type="text/javascript"></script>
        <script>
            var map;
            require(["esri/map", "esri/config",
                     "esri/geometry/Extent",
                     "esri/layers/ArcGISDynamicMapServiceLayer",
                     "esri/layers/ArcGISTiledMapServiceLayer",
                     "esri/layers/FeatureLayer",
                     "esri/renderers/ClassBreaksRenderer",
                     "esri/symbols/SimpleFillSymbol",
                     "esri/tasks/GeometryService",
                     "dojo/dom",
                     "dojo/dom-geometry",
                     "dojo/fx",
                     "dojo/on",
                     "dojo/parser",
                     "dojo/_base/Color",
                     "agsjs/dijit/TOC",
                     "dojo/domReady!"], function (Map, esriConfig, Extent, ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer, FeatureLayer, ClassBreaksRenderer, SimpleFillSymbol, GeometryService, dom, domGeom, coreFx, on, parser, Color, TOC
                         /* The proxy comes before all references to web services */
                         /* Files required for security are proxy.config, web.config and proxy.ashx
                         - set security in Manager to Private, available to selected users and select Allow access to all users who are logged in
                         (Roles are not required)
                         The proxy section is defined on the ESRI sample. I have included it as
                         part of the documentation reads that the measuring will not work.
                         I thought that might be important.
                         // Proxy Definition Begin
                         //identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
                         //If this null or not available the project and lengths operation will not work.
                         // Otherwise it will do a http post to the proxy.
                         esriConfig.defaults.io.proxyUrl = "proxy.ashx";
                         esriConfig.defaults.io.alwaysUseProxy = true;
                         // Proxy Definition End
                         // set custom extent
                         var initialExtent = new Extent({
                             "xmin": 777229.03,
                             "ymin": 1133467.92,
                             "xmax": 848340.14,
                             "ymax": 1185634.58,
                             "spatialReference": {
                                 "wkid": 3435
                         // create map and set slider style to small
                         map = new Map("mapDiv", {
                             showAttribution: false,
                             sliderStyle: "small",
                             extent: initialExtent,
                             logo: false
                         // add imagery
                         var tiled = new ArcGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
                         map.addLayer(tiled);
                         // set operational layers
                         var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", { "opacity": 0.5 });
                         // add operational layers
                         map.addLayer(operationalLayer);
                         // add point feature layer
                         var pointFeatureLayer = new FeatureLayer("http://maps.decaturil.gov/arcgis/rest/services/Test/FeatureServer/0");
                         map.addLayer(pointFeatureLayer);
                         // declare geometry service
                         esriConfig.defaults.geometryService = new GeometryService("http://maps.decaturil.gov/arcgis/rest/services/Utilities/Geometry/GeometryServer");
                         // Add Table of Contents Start
                         map.on('layer-add-result', function (evt) {
                             // overwrite the default visibility of service.
                             //try {
                             toc = new TOC({
                                 map: map,
                                 layerInfos: [{
                                     layer: pointFeatureLayer,
                                     title: "My Feature"
                                     layer: operationalLayer,
                                     title: "Dynamic Map"
                                     layer: tiled,
                                     title: "Imagery"
                             }, 'tocDiv');
                             toc.startup();
                         toc.on('load', function () {
                             if (console)
                                 console.log('TOC loaded');
                         toc.on('toc-node-checked', function (evt) {
                             if (console) {
                                 console.log("TOCNodeChecked, rootLayer:"
  + (evt.rootLayer ? evt.rootLayer.id : 'NULL')
  + ", serviceLayer:" + (evt.serviceLayer ? evt.serviceLayer.id : 'NULL')
  + " Checked:" + evt.checked);
        </script>
    </head>
    <body class="soria">
        <div id="mapDiv">
            <div id="tocDiv"></div>
        </div>
    </body>
</html>
Outcomes
