Relationship classes and offline editing
5503
12
12-05-2014 05:44 AM
WarrenMedernach
Occasional Contributor III
Hello all,
I have a feature class and SQL Server table that I'm trying to relate and make available for offline editing.  I was able to successfully get attachments to a feature working, but I'm having some issues trying to get this to function with my SQL table and I'm assuming it is a schema, primary key issue.
From what I've read on relationship classes and preparing data for offline, layers that participate in a relationship must be related using a Global ID field as the primary key.  So that said, how can this be accomplished if my data is structured such that I have a point feature class with a point 'name' field that is alpha-numeric, and this field is related to a SQL Server table (1:M) with the same alpha-numeric 'name' field?
Any suggestions would be greatly appreciated.
Warren M
RussRoberts
Esri Notable Contributor
They current version of Collector(10.2.7) does not supported relationship classes. This is coming in our 10.3 update which should be out in late December/early Jan.
RussRoberts
WarrenMedernach
Thanks for the info Russell.
But... isn't a feature class 'Attachment' simply a relationship class also?  And this functions offline?  What am I missing?
Warren
RussRoberts
While attachments are an example of related information they are much simpler to model and support.  Notably they contain no attributes that can be edited nor can they have nested relationships.  Collector will be adding support for related data soon, please keep an eye on the blog and news for more information
WarrenMedernach
Awesome, thanks again for the info.
Warren
WarrenMedernach
Hi Russell,
As a followup to this question...
At 10.3 Collector will support relationship classes, so does that mean Collector will be able to add additional related records to an existing feature?  For example, I have a point feature that has 'instrument readings' (1:M) stored in another table and the relationship class exists between these two classes.  Will I be able to add a new 'reading' through the Collector UI?
Warren
RussRoberts
Yup you will be able to view, add, update and delete related records. The example you brought up will be supported. The only thing not supported in this initial release will be M:N relationships.
Russ
WarrenMedernach
And with 10.3 now available, does this mean there is an update for Collector still to come, or should it be functioning now?
Thanks again!
Warren
RussRoberts
There is a 10.3 Collector update coming in January that will bring this support to iOS and Android.
WarrenMedernach
Perfect!
Thanks again for following this and answering all the questions!
Can't wait to get testing this!
Warren
