ARCGIS DESKTOP 10.2
3615
12-05-2014 03:35 AM
ManeshSharma
New Contributor III
Hi all
Can any body let me know  when in python window i type Import Arcpy.
It is giving me error.
can some body help me in the same.
DanPatterson_Retired
arcpy is lowercase
ManeshSharma
New Contributor III
Dan thanks for the reply but I have written in the lower case only then also the same error.
Ok... let me be specific ... can you copy and paste the exact statement you used and the exact error message
for example
>>> import arcpy  # is correct any error message is needed since you probably have a bad install
