Group layers in runtime geodatabase
3802
12-04-2014 04:20 PM
JoshuaBirappagari
I have an mxd file with 2 Group layers, and each of these have layers below them. I did a file -> share as -> runtime content and created a new .geodatabase.
I am using arcgis runtime sdk for .net, how do I access the names of these group layers in c#.
Thanks.
AnttiKajanus1
Occasional Contributor III
Hey,
GroupLayer information is not stored in the geodatabase. Geodatabase stores tables (not layers) so if you want to group FeatureLayers (using Table from the geodabase) you need to create GroupLayers manually in code and set the correct layers under it.
AnttiKajanus1
Hey,
JoshuaBirappagari
Thank you.
