AnsweredAssumed Answered
No results for identify task on visible grouped layers
Question asked by a_morgan on Dec 4, 2014
Latest reply on Jan 20, 2015 by a_morgan
My application loads multiple map services, and within two of the services there are grouped layers (created in ArcMap).  Is it possible to return identify results for sublayers under a grouped layer, when not visible by default?
For example see below, or image attached:
Water Layers  (= map service level)
- Water Valve
- Water Fire Hydrant
- Water Abandoned/Removed  (= layer group, not visible by defaul)
     - Fire Hydrant (A/R)
     - Water Valve (A/R)
     - Water Line (A/R)
- Water Line
Using the "LAYER_OPTION_VISIBLE" layerOption doesn't work.  The "Water Abandoned/Removed" group layer is not visible by default from the mxd settings, so users must make it visible by checking it on the TOC/Legend (widget by NLiu).  With this group layer and all sublayers checked, and when zoomed to a visible scale range, no results are found.
I tried applying your code above with no success either.
My identify code is rather long, as I built a custom info window, but here's where I set the currently visible layers upon map "click" event.  It passes the correct ID's into the array [8,9,10] which equate to Fire Hydrant (A/R), Water Valve (A/R), and Water Line (A/R).  But Identify Task does not produce any results for these three layers.  It only works if I use LAYER_OPTION_ALL, but then I have the obvious problem of returning results from layers not currently visible.
function buildCurrentMapServiceLayerList(serviceLayer) {
             var lyrInfos = {};
             var hasVisibleLayers = false;
             dynamicLayerInfos = serviceLayer.createDynamicLayerInfosFromLayerInfos();
             array.forEach(dynamicLayerInfos, function (info) {
                 var i = {
                 if (array.indexOf(serviceLayer.visibleLayers, info.id) > -1) {
                     i.visible = true;
                     hasVisibleLayers = true;
                 else {
                     i.visible = false;
                 if (!info.subLayerIds) {
                     lyrInfos[info.id] = i;
             if (hasVisibleLayers === true) {
                 mapServiceInfos[serviceLayer.id] = lyrInfos;
Then, to create parameters and execute identify task...
                var serviceName = mapServiceInfos[idxName];
                 for (var idxLayer in serviceName) {   //loop through layers within the current map service
                     var layer = serviceName[idxLayer];
                     if (layer.name.toUpperCase().indexOf("LABEL") == -1 && layer.visible == true) {
                         layersToIdentify.push(layer.id);
                 identifyParams.layerIds = layersToIdentify;
                 identifyParams.tolerance = 8;
                 identifyParams.returnGeometry = true;
                 identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_VISIBLE;
                 identifyParams.width = map.width;
                 identifyParams.height = map.height;
                 identifyParams.geometry = event.mapPoint;
                 identifyParams.mapExtent = map.extent;
                 if (layersToIdentify.length > 0) {
                     var idDeferred = identifyTask.execute(identifyParams, function (idResults) {
                         processIdentifyResults(idResults, event);
(Using js api 3.10 against ArcGIS Server 10.0 services, soon to upgrade to 10.2.2)
Outcomes
