I see there are some newer features in the REST API documentation for the World Geocoding Service. I really like the idea of 'suggest' that lets the user to enter part of an address and get a list of suggested matches.
Is there a way to take advantage of this through the Javascript API, maybe through something like esri.request?
Solved! Go to Solution.
var geocoder = new Geocoder({ map: map, autocomplete: true },"search");
The autocomplete:true property will give suggestions. Is this what you were looking for?
I've always used a locator task and not the geocoder dijit, because I always feel like I have more control with a task compared to the dijits. I guess I need to give the dijit a 2nd look.
The locator task has a suggestLocations method which uses the locator suggest.
Maybe I should try that instead. Going back through a geocoder dijit example, I'm remembering what I didn't like about it in the first place - completely flaky behavior! It will suggest my address, but when I select it to complete the navigation zoom etc, it's takes me instead to some other location entirely! I know I will get nothing but complaints from the end users if I start using this instead.
