Tracking the users of map services published by ArcGIS Server
4053
12
12-01-2014 12:20 AM
HaniDraidi
Occasional Contributor II
Is there a way to track clients who are using a service published by ArcGIS Server and get some information about him/her like IP address, machine name, and how much time he/she used the service?
Any help is appreciated
Thank you and Best Regards,
Hani
MohammedKhamis
Also I want to ask this question .
thanks to help us
larryzhang
Occasional Contributor III
Yes, you can.
Refer to Python code 'Derive map service statistics from the ArcGIS Server logs' at ArcGIS Help (10.2, 10.2.1, and 10.2.2) , which need the role as 'Publisher', at least.
MohammedKhamis
Dear larry ,
thanks for your answer .
Actually I have Question: I don't found username in report , please see in attached , why ? what is problem for that ?
And also I used python code but no results !! I found this massage , see on the attached ..
Thanks for helping .
Regards
larryzhang
An easy way for you to collect statistics as follows, if not often using Python:
1. Login via REST as Admin;
2. And then get access;
          http://[address]:6080/arcgis/admin/services/[gisservice.MapServer_or_ImageServer]/statistics
For get usernames who access, your services should be secured and accessable only to login users. Otherwise, usernames will be empty...
MohammedKhamis
larry,
I did that link , and my services are secured .
but when you enter http://localhost:6080/arcgis/admin/logs/query  , username is empty as you show on the attached
I dont know why ??
larryzhang
HaniDraidi
Many thanks Larry for your prompt response,
I accessed the statistics page, but the information provided by the page does not include the IP address or the machine name of the client. (Attached)
I can access the page for non-secured services
larryzhang
To collect the info of clients' IP or PC ID, it would be nice request. Not sure if ESRI server team is aware of this need, in operation.
However, you can find out a solution via other ways like Remote IP TrackerTM
HaniDraidi
Many Thanks Larry
