Control for setting MapScale
3348
11-26-2014 11:21 PM
AnatoliiTerentiev
Occasional Contributor III
Dear Gurus!
I would like to implement MapScale control as it done in arcgis Desktop.
I put on View ComboBox , bind SelectedValue of ComboBox  to SelectedMapScale in MapViewModel.
In arcObjects I did this as follows:
axMapControl1.MapScale = SelectedMapScale ;
How to set the desired map scale with  arcgis API for WPF?
AnatoliiTerentiev
I found experimentally approximate coefficient connecting resolution and MapScale. Thus, when SelectedMapScale changed  I do the following operations:
Map.ZoomToResolution( SelectedMapScale * 0.0002644, mapPoint);
DominiqueBroux
Esri Frequent Contributor
There is a ScaleLine control in the toolkit which might help.
There is also a scaleline sample showing how the control can be customized.
AnatoliiTerentiev
Thank you, Dominique!
