How do I remove the print_button after the printing has completed?
1527
5
11-26-2014 12:20 PM
ChrisSergent
Regular Contributor III
I have extended my print widget so that I can enter a title, choose the layout and format, by creating a second button to input these values prior to clicking on print. How do I remove the print_button after the printing has completed? I tried writing a printer on complete function, but it did not work.
<!DOCTYPE html>
<html>
    <head>
        <title>Print a Map</title>
        <meta http-equiv="content-type" content="text/html; charset=utf-8">
        <meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/soria/soria.css">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
        <style>
            html, body, #mapDiv
                padding:0;
                margin:0;
                height:100%;
                width:100%;
                position:absolute;
                z-index:0;
            /* Printer CSS Begin */
            h3 { margin: 0 0 5px 0;
                 border-bottom: 1px solid #444;
                 padding: 0 0 5px 0;
                 text-align: center;
              .shadow
                -moz-box-shadow: 0 0 5px #888;
                -webkit-box-shadow: 0 0 5px #888;
            #feedback
                background: #fff;
                border: 2px solid #666;
                border-radius: 5px;
                bottom: 20px;
                color: #666;
                font-family: arial;
                height: auto;
                left: 20px;
                margin: 5px;
                padding: 10px;
                position: absolute;
                width: 300px;
                z-index: 40;
                visibility:hidden;
            #feedback a
                border-bottom: 1px solid #888;
                color: #666;
                text-decoration: none;
            #feedback a:hover, #feedback a:active, #feedback a:visited {
                border: none;
                color: #666;
            #note
                padding: 0 0 10px 0;
            #info, #information
                padding: 10px 0 0 0;
            /* Printer CSS End */
            #showTools
                height:20px;
                width:20px;
                position:absolute;
                top:200px;
                left:20px;
                z-index:50;
                padding:5px 6px 5px 6px;
                background-color:#f9f8f8;
                border-radius:5px;
                visibility:visible;
            #hideTools
                height:20px;
                width:20px;
                position:absolute;
                top:200px;
                left:20px;
                z-index:50;
                border-radius:5px;
                visibility:hidden;
            #printer
                height:20px;
                width:20px;
                position:absolute;
                top:240px;
                left:20px;
                z-index:50;
                border-radius:5px;
                visibility:hidden;
        </style>
        <script src="http://js.arcgis.com/3.11/"></script>
        <script>
            var app = {};
            require(["esri/map", "esri/config",
                     "esri/dijit/Print",
                     "esri/geometry/Extent",
                     "esri/layers/ArcGISDynamicMapServiceLayer",
                     "esri/layers/ArcGISTiledMapServiceLayer",
                     "esri/layers/FeatureLayer",
                     "esri/tasks/GeometryService",
                     "esri/tasks/PrintTemplate",
                     "dojo/_base/array",
                     "dojo/dom",
                     "dojo/on",
                     "dojo/parser",
                     "dijit/layout/BorderContainer",
                     "dijit/layout/ContentPane",
                     "dojo/domReady!"], function (Map, esriConfig, Print, Extent,
                                                  ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer,
                                                  FeatureLayer, GeometryService, PrintTemplate, arrayUtils, dom, on, parser
                         parser.parse();
                         /* The proxy comes before all references to web services */
                         /* Files required for security are proxy.config, web.config and proxy.ashx
                         - set security in Manager to Private, available to selected users and select Allow access to all users who are logged in
                         (Roles are not required)
                         The proxy section is defined on the ESRI sample. I have included it as
                         part of the documentation reads that the measuring will not work.
                         I thought that might be important.
                         // Proxy Definition Begin
                         //identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
                         //If this null or not available the project and lengths operation will not work.
                         // Otherwise it will do a http post to the proxy.
                         esriConfig.defaults.io.proxyUrl = "proxy.ashx";
                         esriConfig.defaults.io.alwaysUseProxy = false;
                         // Proxy Definition End
                         // set custom extent
                         var initialExtent = new Extent({
                             "xmin": 777229.03,
                             "ymin": 1133467.92,
                             "xmax": 848340.14,
                             "ymax": 1185634.58,
                             "spatialReference": {
                                 "wkid": 3435
                         // create map and set slider style to small
                         var map = new Map("mapDiv", {
                             showAttribution: false,
                             sliderStyle: "small",
                             extent: initialExtent
                         // add imagery
                         var tiled = new ArcGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
                         map.addLayer(tiled);
                         // set operational layers
                         var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", { "opacity": 0.5 });
                         // add operational layers
                         map.addLayer(operationalLayer);
                         // add point feature layer
                         var pointFeatureLayer = new FeatureLayer("http://maps.decaturil.gov/arcgis/rest/services/Test/FeatureServer/0");
                         map.addLayer(pointFeatureLayer);
                         // declare geometry service
                         esriConfig.defaults.geometryService = new GeometryService("http://maps.decaturil.gov/arcgis/rest/services/Utilities/Geometry/GeometryServer");
                         // begin print widget
                         app.printUrl = "http://maps.decaturil.gov/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%2...";
                         function createPrintDijit(printTitle) {
                             var layoutTemplate, templateNames, mapOnlyIndex, templates;
                             // create an array of objects that will be used to create print templates
                             var layouts = [{
                                 //name: "Letter ANSI A Landscape",
                                 label: "Landscape (PDF)",
                                 //format: "pdf",
                                 options: {
                                     legendLayers: [], // empty array means no legend
                                     scalebarUnit: "Miles",
                                     titleText: printTitle
                             // create print templates
                             var templates = arrayUtils.map(layouts, function (lo) {
                                 var t = new PrintTemplate();
                                 t.layout = document.getElementById("printLayoutId").value;
                                 t.label = lo.label;
                                 t.format = document.getElementById("printFormatId").value;
                                 t.layoutOptions = lo.options;
                                 return t;
                             app.printer = new Print({
                                 map: map,
                                 templates: templates,
                                 url: app.printUrl
                             }, dom.byId("print_button"));
                         // end of print widget
                         // Hides print button
                         app.printer.on('print-complete', function () {
                             document.getElementById("print_button").style.visibility = 'hidden';
                         // Activates printer
                         on(dom.byId("btnPrintReady"), "click", function () {
                             createPrintDijit(document.getElementById("printTitleId").value);
                             app.printer.startup();
                         // Hides print widget
                         on(dom.byId("closePrint"), "click", function () {
                             document.getElementById("feedback").style.visibility = 'hidden';
                         // Shows tools
                         on(dom.byId("showTools"), "click", function () {
                             document.getElementById("showToolsButton").style.visibility = 'hidden';
                             document.getElementById("hideToolsButton").style.visibility = 'visible';
                             document.getElementById("printer").style.visibility = 'visible';
                         // Hide tools
                         on(dom.byId("hideTools"), "click", function () {
                             document.getElementById("showToolsButton").style.visibility = 'visible';
                             document.getElementById("hideToolsButton").style.visibility = 'hidden';
                             document.getElementById("printer").style.visibility = 'hidden';
                         // Show print widget
                         on(dom.byId("showPrintWidget"), "click", function () {
                             document.getElementById("feedback").style.visibility = 'visible';
        </script>
    </head>
    <body class="soria">
        <!-- Map Div Begin -->
        <div id="mapDiv">
        <div id="showTools">
            <input type="image" id="showToolsButton" src="images/hammer.png" alt="Show Tools" title="Show Tools" />
        </div>
        <div id="hideTools">
            <input type="image" id="hideToolsButton" src="images/close.ico" alt="Hide Tools" title="Hide Tools" />
        </div>
        <div id="printer">
            <input type="image" id="showPrintWidget" src="images/print.ico" alt="Print" title="Print" />
        </div>
            <form id="frmPrint" action="" onsubmit="return false;">
                <div id="feedback">
                <h3>
                    City of Decatur Print Service
                </h3>
          <div id="information">
            <div id="note">
              Note:  Select the format that you would like to print your map from the dropdowns below.
            </div>
                <!-- used for the print dijit -->
                <label id="lblPrintTitle">Enter a print title</label><br />
                <input type="text" id="printTitleId" name="printTitle" value="Street Light Inventory" />
                <br /><br />
                <select name="printLayout" id="printLayoutId">
                    <option value="A3 Landscape" selected>A3 Landscape</option>
                    <option value="A3 Portrait">A3 Portrait</option>
                    <option value="A4 Landscape">A4 Landscape</option>
                    <option value="A4 Portrait">A4 Portrait</option>
                    <option value="Letter ANSI A Landscape">Letter ANSI A Landscape</option>
                    <option value="Letter ANSI A Portrait">Letter ANSI A Portrait</option>
                    <option value="Tabloid ANSI B Landscape">Tabloid ANSI B Landscape</option>
                    <option value="Tabloid ANSI B Portrait">Tabloid ANSI B Portrait</option>
                </select>
                <select name="printFormat" id="printFormatId">
                    <option value="pdf" selected>PDF</option>
                    <option value="png32">PNG32</option>
                    <option value="png8">PNG8</option>
                    <option value="jpg">JPG</option>
                    <option value="gif">GIF</option>
                    <option value="eps">EPS</option>
                    <option value="svg">SVG</option>
                    <option value="svgz">SVGZ</option>
                </select>
            <br /><br />
            <button type="button" id="btnPrintReady">Print Ready</button>
            <div id="print_button"></div>
            <div id="info">
              This print service is to be used for City business only.
              <input type="image" id="closePrint" src="images/close.ico" alt="Close" title="Close" />
            </div>
          </div>
        </div>
            </form>
        </div>
        <!-- Map Div End -->
    </body>
</html>
Tags (1)
RobertScheitlin__GISP
Chris,
  I think this attached code is more along the lines of what you are looking for.
YungKaiChin
Have you tried style.display = "none"?
Maybe the event was not fired.
ChrisSergent
I need to know how to capture the event. The print task works.
Chris,
   You can not put an "on" on a dijit that is not yet created. Move your app.printer.on 'print-complete' to the inside of the btnPrintReady on function, after the app.printer.startup()
Next you do not want to hide the print_button as that will have the link to the download after the print is generated.
I would be hiding the btnPrintReady right after it is clicked and then figure out how to show it after the "Printout" anchor is clicked.
Chris,
ChrisSergent
Exactly what I was looking for. Thanks again Robert!
