Python toolbox (pyt): how to get output
3416
6
11-25-2014 10:40 AM
KevinBell
Occasional Contributor III
It would be tremendously helpful if someone could post a sample python toolbox (pyt) that accepts a dummy input parameter or two, and returns "hello world of pyt gp services!"  I figure with that template, I could do my own gp routines during the execution, and replace the "hello world" with the results of my gp work.  I don't need any geometry returned, just text.
The use case here is to return nearby addresses from an input lat/long.
This code fails:
import arcpy
import os
class Toolbox(object):
    def __init__(self):
        self.label = "Get Nearby Addresses"
        self.alias = ""
        # List of tool classes associated with this toolbox
        self.tools = [GetNearbyAddresses]
class GetNearbyAddresses(object):
    def __init__(self):
        self.description = "Get Nearby Addresses within a buffer."
        self.canRunInBackground = False
    def getParameterInfo(self):
        params = []
        param0 = arcpy.Parameter(
            displayName = "Latitude",
            name = "lat",
            datatype = "Double",
            parameterType = "Required",
            direction = "Input")
        params.append(param0)
        param1 = arcpy.Parameter(
                    displayName = "Longitude",
                    name = "lon",
        params.append(param1)
        param2 = arcpy.Parameter(
            displayName = "Buffer Distance",
            name = "distance",
            datatype = "Long",
        params.append(param2)
        param3 = arcpy.Parameter(
                    displayName = "Address List",
                    name = "addresses",
                    datatype = "GPString",
                    parameterType = "Derived",
                    direction = "Output")
        params.append(param3)
        return params
    def execute(self, parameters, messages):
        try:
            arcpy.env.workspace = r'E:\gis\default.gdb'
            lat = parameters[0].valueAsText
            lon = parameters[1].valueAsText
            distance = parameters[2].valueAsText
            #inpoint = arcpy.Point(X=lon, Y=lat)
            #ptGeometry = arcpy.PointGeometry(inpoint, arcpy.SpatialReference(4326))
            #arcpy.Buffer_analysis(ptGeometry, 'buffer', distance + ' FEET', \
            #                      "FULL", "ROUND", "NONE", "")
            #get intersecting addresses here
            parameters[3].value = 'a nice list of addresses!'  # I need this from a gp service!
            return
        except Exception, ErrorDesc:
            sErr = "ERROR:\n" + str(ErrorDesc)
            messages.addErrorMessage(sErr)
        return
DallasShearer
if you just want to add the results to the toolbox messages. just add:
arcpy.AddMessage("your list results")
if you want to add the results to a text file. do it like this:
with open(r"c:\yourdirectory\yourfile.txt", "w") as f:
     f.write("your list results")
I don't think you necessarily need to define an output parameter (param3), unless your intention is to add it to arcmap on completion.
KevinBell
I have web developers that would like to consume the results as a web service, so I'm not too clear on the best way to set the output, but I don't think adding to the tool message is it.  I don't really need to persist the data to a text file either.  It's a quick call to get some temp data, then it's tossed.
MarkJones7
How would you get that text file to the user? I am working on a geoprocessing task and I need to send a file back to the user (allowing them to select where on their own computer they would like to save the file).
AhmedEl-Sisi
Try to set your output parameter like the following:
arcpy.SetParameter(3,'a nice list of addresses!')
KevinBell
hmmm....   submitting the job via the rest directory fails still.  The tool succeeds in ArcMap though.
DallasShearer
ok, i didn't realize you were wanting to publish to the rest service. I copied your code from above and it displayed the output as it should...
