AnsweredAssumed Answered
ArcGIS Help 10.1 - Creating a Python add-in button. This is not working for me, please help.
Question asked by spencerlank on Nov 24, 2014
I'm following a tutorial here: ArcGIS Help 10.1
I have added the code to the .py file and installed the add-in in using the makeaddin.py file and Test001.esriaddin file yet when I press the button, nothing happens. It's supposed to zoom to the selected features. I have ArcMap 10.2 and indicated so in the Python Add-In Wizard provided by ESRI. Attached is the .py file, . Here is the code:
import arcpy
import pythonaddins
class ZoomToSelectedFeatures(object):
    """Implementation for Test001_addin.btn1 (Button)"""
    def __init__(self):
        self.enabled = True
        self.checked = False
       # Implementation of OnClick method of Button's class
       def onClick(self):
            # Get the current map document and the first data frame.
            mxd = arcpy.mapping.MapDocument('current')
            df = arcpy.mapping.ListDataFrames(mxd)[0]
            # Call the zoomToSelectedFeatures() method of the data frame class
            df.zoomToSelectedFeatures()
Thank you in advance for taking the time to help.
Outcomes
