Onclick event for a sublayer in a ArcGISDynamicMapServiceLayer
2754
11-25-2014 02:39 AM
NEvatt
New Contributor III
Hi there,
I have an ArcGISDynamicMapServiceLayer which consists of maybe 40 or so sublayers and I would like to trigger an onclick event for a specific sublayer within an ArcGISDynamicMapServiceLayer.  For instance, if I select a polygon of the sublayer, I want to create a chart in a seperate div. This is pretty easy to do with FeatureLayers, ie:
var featureLayer = new esri.layers.FeatureLayer("https://blah blah blah", { options  });
featureLayer.on("click", function (evt) {
     // Do something
However, I am not sure if this is possible with ArcGISDynamicMapServiceLayer.
The reason that I am hoping to add an event to a sublayer is that i need the sublayers to sit underneath the top layer in a table of contents view. The only other way that I can come up with is to put several featureLayers together and somehow group them in a group layer within the table of contents.  I am also not sure how to do this, but in theory this could be possible.
Any ideas?
thanks,
Nat
JakeSkinner
Esri Esteemed Contributor
Hi N Evatt,
You can use the IdentifyTask class to do this.  Below is an example:
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Sample Map</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
    <style>
      html, body, #mapDiv {
        padding:0;
        margin:0;
        height:100%;
    </style>
    <script src="http://js.arcgis.com/3.11/"></script>
    <script>
      var map;
      require([
        "esri/map", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/tasks/IdentifyTask", "esri/tasks/IdentifyParameters",
        "dojo/dom", "dojo/on", "dojo/_base/array", "dojo/domReady!"
      ], function(
        Map, ArcGISDynamicMapServiceLayer, IdentifyTask, IdentifyParameters,
        dom, on, array
        map = new Map("mapDiv", {
          basemap: "streets",
          center: [-81.792107, 26.150807],
          zoom: 8
        map.on("load", initFunctionality);
        var dynamicLayer = new ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer", {
          opacity: 0.5
        map.addLayer(dynamicLayer);
        function initFunctionality () {
          map.on("click", doIdentify);
          identifyTask = new IdentifyTask("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer");
          identifyParams = new IdentifyParameters();
          identifyParams.tolerance = 3;
          identifyParams.returnGeometry = true;
          identifyParams.layerIds = [0, 3];
          identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL;
          on(identifyTask, "complete", function(event){
            array.forEach(event.results, function(feature){
              if(feature.layerName == "Counties"){
                //Do Something
        function doIdentify (event) {
          map.graphics.clear();
          identifyParams.geometry = event.mapPoint;
          identifyParams.mapExtent = map.extent;
          identifyTask.execute(identifyParams)
    </script>
  </head>
  <body>
    <div id="mapDiv"></div>
  </body>
</html>
JakeSkinner
Hi N Evatt,
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
        padding:0;
        margin:0;
        height:100%;
    </style>
    <script>
      var map;
      require([
      ], function(
        dom, on, array
          basemap: "streets",
          zoom: 8
          opacity: 0.5
                //Do Something
    </script>
  </head>
  <body>
  </body>
</html>
NEvatt
New Contributor III
Jake, that is great.  Thanks so much.  Did just what I needed it to
