Wondering if anyone else has seen this strange issue:
I have a dojox/mobile/TextBox that is the input for a query task.
When I use my keyboard ten key, the map pans; the only values that will populate are 0 and 5, the others will pan the map in the logical direction of the key (i.e. 3 pans southeast). This happens if NumLock is on or off.
The top keyboard numbers seem to function as expected.
Any ideas appreciated,
PW
Solved! Go to Solution.
Patrick,
Have you tried disabling keyboard navigation on the map when the textbox has focus and re-enabling when focus is lost?
map.disableKeyboardNavigation();
Patrick,
