Strange ArcMap behavior?
2417
5
11-18-2014 04:02 AM
JohannesBierer
Occasional Contributor III
One layer classified with LRTCODE. I want to change symbols. If I open the propertiers dialog, there's one symbol without classification where should be classified by LRTCODE?
Any ideas, workaround?
DanPatterson_Retired
Johannes...the first thing I would do is try that particular file in a new project to see if all the legend options appear.
the second try would be to remove the layer, save the project, add the layer to a new data frame and try the legend thing
if the second doesn't work, remove again, add to the original data frame and try again (don't just drag it from one frame to another)
If the first doesn't work...it is the file
if the second doesn't work it may be the project
if the third doesn't work it may be that data frame
finally...is that layer really that important ???
Johannes do you not have it currently have it set to single symbol? did you try the next one down?
JohannesBierer
Dan, thanks the thing. In this Layer the next down is gone 🙂
Sorry it's german, the classification Menufield is called there Kategorie.
The normal view (with five possibilities to choose):
If you compare this with the one in the first post, there's Kategorie missing
JohannesBierer
In the data view there's the correct legend (First image), but if I open properties to change some colors I get the single symbol ?
Quite funny, but I need to change the map. MxdDoctor?
JohannesBierer
Thanks there was a 'unsientific' solution. I build the Layer symbology new, in the geodata slave style.
No matter of life and death
