ArcGis 10.1 rename column sequence
1469
11-15-2014 09:12 AM
MicheleLucchi
Arcgis 10.1 / give a query, I order my column sequence in ascending order (eg 1-2-2.1-2.2-3-4-etc), I have to rename the same sequence (ie 1-2-3-4-5-6-7 etc.) please someone know the solution?
I tried the Autoicrement ()
     rec = 0
     final autoIncrement ():
      global rec
      PStart = 1 #adjust start value, if req'd
      pInterval = 1 #adjust interval value, if req'd
      if (rec == 0):
       rec = PStart
      else:
       rec = rec + pInterval
      return rec
It performs randomly the rename column (for example the number 1 that must be the 1 becomes 180 uses OID)
Thank you so much
Michele
Tags (1)
XanderBakker
Esri Esteemed Contributor
ArcGIS Team Python posted a nice example with python to add a rank field (but don't use the category field): Ranking field values | ArcPy Café
This post also shows a python solution for your problem:
https://community.esri.com/message/128653#128653
Kind regards, Xander
MicheleLucchi
Thank you for showing me this article, I will try soon and tell you if it does work.
Thank you so much
Michele
