AnsweredAssumed Answered
Export report tool box
Question asked by ilanazaria on Nov 16, 2014
Latest reply on Nov 16, 2014 by ilanazaria
I try to build a tool that export report to pdf  file.
I used this example: ArcGIS Help 10.1 and I added parameters to a toolbox and write the python script:
# Date:    November 11, 2014
#          parameters:
#           1) Select Map Documents,
#             2) select data frame
#             3) Select Layer (points).
#            4) select report file (RLF).
#            5) Export report as pdf file.
import arcpy
#Read input parameters from script tool
#Select Map Documents
mxdPath = arcpy.GetParameterAsText(0)
#select data frame
dfName = arcpy.GetParameterAsText(1)
#  Select Layer (points).
feature = arcpy.GetParameterAsText(2)
#select RLF file
report= arcpy.GetParameterAsText(3)
#select PDF file name
exportfile= arcpy.GetParameterAsText(4)
mxd = arcpy.mapping.MapDocument(mxdPath)
df = arcpy.mapping.ListDataFrames(mxd, dfName)[0]
lyr = arcpy.mapping.ListLayers(mxd, feature, df)[0]
arcpy.mapping.ExportReport(lyr,report,exportfile)
del mxd
Error message:
Someone have an idea what can be the the reason for this error?
Outcomes
